Rear main seal pouring oil
Well last year when I had my T56 rebuilt I replaced the rear main seal and rear cover gasket. That was about 10k miles ago and had no problems. Last night I had a puddle of oil under the car, got it home quick (was less than a mile from home) and looked underneath and it was leaking between the motor and bellhousing. I'm just wondering why it would all of a sudden start pouring out like that out of nowhere. Replaced with genuine GM seals, put them in dry and everything. I'm just lost on why all of a sudden oil started pouring out. Not looking forward to laying on my back and pulling the trans again but it is what it is I guess. Fingers crossed my new clutch isn't shot too. That's another question, if there is oil on the disk, can it be cleaned or should I at the minimum get a new clutch disk. I'd love to upgrade it completely to a monster clutch but just can't afford it right now.
Your clutch is done if it got saturated with oil. Are you sure it's oil? Not clutch fluid or transmission fluid? Seals just don't all of a sudden "let go". Check and make sure the oil isnt coming from up top. Valve cover? OP sender? etc
Yea it's oil, its black and I was just about to change the oil. I'll check valve covers and possibly the oil pan gasket. I know the oil pan gasket was seeping and that was next on my to do list, but it was dripping out between the bellhousing and the motor. Now if the clutch is saturated with oil, can I just get a new disc and have the flywheel resurfaced? Or will the pressure plate be shot too?
I honestly haven't gotten underneath it yet. Just looked from the side. It looked like from the center but I'll have to climb underneath there. Now if it is the pan gasket I know the k member has to come down to get the pan out, but does the trans have to come out to unbolt the pan? I don't remember when I had it out last time
If this just started that quickly i would say you have a leaking oil pressure sender. I have seen the rear cover leak from the top and run down but thats not likely if you just replaced that. I would look at that sender before anything.
Ok, I'll probably check that out tomorrow, I checked the oil level and it's about 1/2 a quart low. fingers crossed its that cause I would rather pull the intake than the trans. If I had access to a lift, i wouldn't care but on your back, pulling the trans SUCKS
OK looks like it is the OPSU. As soon as I tried to disconnect the plug the entire thing came apart. Will know 100% sure that was the issue when I get it back together tomorrow. Would be now, but need an intake manifold gasket which wont be in til tomorrow
So as I was putting my intake back into, one of my intake bolts snapped off in the head.......FML. I'm lost on how, because it was the 4th bolt i was putting in, had the torque wrench set to 8 ft lbs and it just snapped. Did it at 4 ft lbs first. Guess I'll be putting all new intake bolts now. Head is already off. Just wondering if I should just pull the other one and replace the head gasket while I'm halfway there
If you have the money now while the heads are off at a minimum drop in a new set of ls2 lifter buckets...I think they were around $16 a pair when I got them a few years ago, you'll if they still come in pairs you will need two sets (4) buckets all together.
Well I think I'm just going to replace the head gasket and bolts on that side for now. Next winter I am doing heads and cam so it will come off again then. Just can't afford it now. Want to drive the car this summer, want to get it to the track to to see where I'm at now. but I appreciate everyones help
