durabond cam bearings
Old 06-02-2013, 04:49 PM
baronsmith98's Avatar
Default durabond cam bearings
Anybody ever have trouble with durabond cam bearings? Just got some in and the OD is fine but the ID is .009 too big not to mention burrs on every bearing.
Old 06-02-2013, 05:20 PM
Gray86hatch's Avatar
re-measure once installed
Old 06-02-2013, 07:23 PM
ckpitt55's Avatar
What pn did you get, chp-10's?
Old 06-02-2013, 07:52 PM
Yes that is the part number. There is even a small nick on the inside of one. Really dissappointed in the quality on these ill be sending them back
Old 06-02-2013, 11:57 PM
ckpitt55's Avatar
interesting. I have the same ones awaiting install. No idea on the sizes but I did notice a couple coating burrs in / near the oiling holes.
Old 06-03-2013, 01:17 AM
If you dont mind when you check yours let me know what they measure. Im interested if this is a common problem. I was just amazed at how rough they were
Old 06-03-2013, 06:45 AM
ckpitt55's Avatar
I will. When you say they were 0.009 too big, do you mean you couldn't even install the cam or that the clearances were excessive? Either way at 0.009 it wouldn't even be close.
Old 06-03-2013, 09:55 AM
KCS
Moderator
KCS's Avatar
They install with a press fit, so the ID will shrink.
Old 06-03-2013, 12:51 PM
My clearances are excessive
Old 06-03-2013, 01:24 PM
ckpitt55's Avatar
As others have asked, you have the bearings installed in the block right?
Old 06-03-2013, 02:24 PM
Yes i have them installed
Old 06-03-2013, 03:12 PM
KCS
Moderator
KCS's Avatar
That's strange, they're rarely ever that big. I had .0005" - .0025" clearance with my Durabond bearings and Comp cam.
Old 06-03-2013, 04:00 PM
Yeh the cam literally flops around with the clearances that big. Im going to send them back and get a new set
Old 06-03-2013, 08:07 PM
KingPin1094's Avatar
Those are the ones that i have, and they worked perfectly fine for me. No issues whatsoever
Quick Reply: durabond cam bearings
