Will GM MLS head gaskets work on a 2001 Trans Am??
Old 07-26-2013, 08:56 PM
Holy Diver's Avatar
Default Will GM MLS head gaskets work on a 2001 Trans Am??
Hi all, I have a slow head gasket leak (losing coolant, puffs white sweet smelling smoke on startup, and idles a little rough when cold). I need to fix this before it gets worse. So can I use the GM MLS head gaskets that are listed for 2002-2004 LS1s on my 2001? Will it change the compression ratio?
I heard that MLS is better than graphite... can handle more power and it's not a bitch to clean off when I hopefully get the opportunity to put some awesome heads on the car. I have a light bolt-on 2001 Trans Am with the LS6 block. Thanks!
Old 07-26-2013, 09:42 PM
zzcamaro00's Avatar
on the earlier LS1 heads the 853s i think they have an indentation on the head itself, if you have this indentation you MUST you use the graphite gasket or you will have sealing issues
Old 07-26-2013, 09:55 PM
Holy Diver's Avatar
10-4... just curious, would Cometic MLS gaskets work on the older head?
Old 07-27-2013, 12:39 PM
Holy Diver's Avatar
Also, heads are 241... Will GM MLS gaskets work with these even tho it's a 2001?
Old 07-27-2013, 01:08 PM
Trunion King
bene's Avatar
I used GM MLS gaskets on mine when I swapped my 241 heads to 243. My car is 2000.
The factory head gaskets were graphite.
Old 07-27-2013, 06:19 PM
PREDATOR-Z's Avatar
Yes...
Old 07-27-2013, 07:40 PM
Holy Diver's Avatar
K thanks guys. This is weird... It never ran weak, never mixed coolant and oil, never overheated. Pulled the plugs today.. cylinder 7 (last on driver's side) told the story. Pretty sure it's a little coolant seeping in there after it sits overnight then you see the plume of white smoke on startup. Happened after I replaced my old, original radiator cap. The spring was so weak it wouldn't go up to the stock 18 psi. So the gaskets started seeping coolant when the pressure built up. That's my theory anyways lol
Old 07-28-2013, 02:21 PM
wildcamaro's Avatar
Yes sir
Old 07-28-2013, 04:19 PM
KCS
Moderator
KCS's Avatar
I believe Fel Pro is making a MLS gasket to use on those older heads.
Quick Reply: Will GM MLS head gaskets work on a 2001 Trans Am??
