read my plugs. doesn't look good to me
So I changed my plugs at lunch today. I drive the car home and got on it twice right before I got home
I pulled one plug since it was hotter than all get out. Looks really white to me. I'm having overheating and cooling system pressure and spewing from cap issues.
don't remove plugs from a hot aluminum head.the head heats up and clamps tighter on the plug.to read plugs correctly you shut the engine off after a run ,then remove the plugs .try a new pressure cap ,is you coolant system bleed correctly ?
