HELP!!! 2000 rpm vibration
Hey everyone, hoping someone can help. I have a 98 TA with a freshly rebuilt motor. It's got a oreillys stock replacement harmonic balancer, new spec stage 3 clutch and steel flywheel, Magnaflow exhaust and a mail order tune.
Whether the car is in neutral or gear, it has a vibration thoughout that can be felt through the steering wheel. I got quiet a bit of piston slap on startup and worried it could possibly the motor.
Any thoughts?
Thanks
Brian
Any thoughts?
Thanks
Brian
Motor
347 ls1 block with 243 heads. Mahle pistons, stock rods and arp rod bolts, motor has 222/224 comp cam. Opel engineering in Schaumburg, Il was the engine builder.
I know Ted at Opel and they are located in Streamwood not Schaumburg. He machined my block and balanced my rotating assembly, I built the motor. He provided me with the balance sheets and was very helpful, call him up or bring the car to him and he should help you out. I know a lot of people in my area who use Opel with no issues and they have a good reputation with the sportsman racers around here so I would be very surprised if something was wrong with the motor. Keep us updated.
