Selecting the correct cam - Your help/opinion appreciated
Hey guys,
So I posted this over at another forum site which I believe is affiliated - but then realized this site is probably where I should have posted.
I have a 2000 C5 A4. After failure of my engine builder to properly spec the motor - I have taken on the job. I wanted to see what cam specs you guys might recommend with this setup:
LS1 - Bored .005 over / Standard stroke
FAST 92mm Intake
90mm TB
42# Injectors
Trickflow Fast as Cast 220 Heads
Flat top forges pistons with 3cc valve recesses.
11.04:1 Compression
Comp cams 1.72 roller rockers
7.40 Trick Flow push rods
3000 Stall T/C
What duration cam would you guys go with for max power - while retaining drive-ability. My dyno guy is recommending:
236-238 intake
234-235 exhaust
110-112 lsa
.600 lift
Seems a little small to me... I want to use these good flowing heads. What do you guys think?
Here are all the specs for the engine if you want:
Bore size: 3.903
Stroke: 3.633
Head gasket: .050
Head gasket bore: 3.998
Valve recesses in pistons (flat top): .155
Valve Recess (cc): -3cc
Squench: -.017
Head Specs:
trickflow generation X
FAST AS CAST 220 cylinder heads for LS2
205.5 intake valve
1.570 exhaust valve
65cc chamber volume (milled down to 61cc)
First we need to break some things down.
Cylinder volume = 0.7853982 x bore2 (squared) x stroke
so
Cylinder volume = 0.7853982 x 15.233409 x 3.633
Cylinder volume = 43.46627286674899
Clearance volume = 0.7853982 x bore2 x squench
Clearance volume = 0.7853982 x 15.233409 x .017
Clearance volume = -0.2033929641438846
Piston dome or dish (valve recess) in cubic inches = cc's x 0.0610237
Piston Volume = 3 x 0.0610237
Piston Volume = 0.1830711
Head-gasket volume = 0.7853982 x gasket bore2 (squared) x compressed thickness
Head-gasket volume = 0.7853982 x 15.984004 x .050
Head-gasket volume = 0.62769039851964
Chamber volume in inches = cc's x 0.0610237
Chamber volume in inches = 65 x 0.0610237
Chamber volume in inches = 3.9665405
Then we take this formula:
Compression Ratio =
Cylinder vol. + clearance vol. + piston Comp. vol. + gasket vol. + chamber vol. divided by Clearance vol. + piston vol. + gasket vol. + chamber vol.
So:
Chamber volume in inches = 61 x 0.0610237
Chamber volume in inches = 3.7224457
Compression Ratio = (43.46627286674899 + (-0.2033929641438846) + 0.1830711 + 0.62769039851964 + 3.7224457) / ((-0.2033929641438846) + 0.1830711 + 0.62769039851964 + 3.7224457)
Compression Ratio = 47.7960871011248 / 4.32981423437576
Compression Ratio = 11.0388308860128
Compression Ratio = 11.04:1
FAST 92mm Intake
90mm TB
42# Injectors
11.04:1 Compression
3000 Stall T/C
236-238 intake
234-235 exhaust
110-112 lsa
.600 lift
Bore size: 3.903
Stroke: 3.633
Head gasket: .050
Squench: -.017
Head Specs:
205.5 intake valve
1.570 exhaust valve
so
Compression Ratio =
So:
Brian Tooley is, in my opinion, the person you should contact for your camshaft and TFS head.
http://www.briantooleyracing.com/
He has the most experience with this head. Although I'm sure many will also give Martin at http://www.tickperformance.com/contact/
As a camshaft recommendation.
And as far as cam size... I guess it's all relative... But I just didn't want to go through all of this and not spec this right. A lot of money has gone down this hole so as everyone - just looking for maximum $$$ to HP ratio.
(I had a 226 229 .600 lift @ .050 112 lsa and did not cam nearly as much as I expected and definitely was missing some power I expected.)
The reason I ripped it all back apart and started over is because the builder didn't calculate the lift correctly and bottomed all of my valve stem seals on the valve guides. Figured while I'm here I'd up my compression to 11:1 and up my cam. Just looking for that magical number. (and I know its different for everyone)
Super Hulk Smash
Something like what I have would work... EPS 234/242 .605"/.605" 111+3 LSA...
In fact, Brian Tooley and Martin Smallwood both have shelf cams that are very similar. 235/242 111 cams.
To me, that's the best balance of all out power while still being somewhat streetable. 16 degrees of overlap is still quite a bit tho. Just throw a **** ton of compression at it and get a good tune. And presto.
I have not heard that these rockers will hurt me on aggressive lobes. Why is that?
I believe I have a 3.42 rear end. (looking in HPtuners at final gear ratio.) Please lead me down the right road if this is not correct. I purchased this not too long ago so still learning LS engines, Corvettes, and HPtuners. Former ford guy here. (I dont discriminate)
Thanks for all the help you guys are providing! Ready to purchase but waiting to get some opinions.
You need to just look at the tag on the differential to see what gear ratio you have, C5 A4 came with 2.73 or 3.15, unless someone changed it.
If you put the cams mentioned in, anything over 230 on the intake and you aren't going to like the 3000 stall, you will want more like 3600-4000.
Ron (from that "other" site)
If you put the camsmentioned in, anything over 230 on the intake and you aren't going to like the 3200 stall, you will want more like 3600-4000.
Just looked and the rear end is tagged 3.15... Not sure if it was changed before I purchased. 3.45 in HP tuners on Final Gear Ratio.
Sigh... These torque converters are not cheap!
I would look at something like the hellraiser or ssht from FTI, or something speced from someone similar but being and smallish stall would keep it under 230, but the experts would have more insight for this app and the handicapps you may be facing combination wise.
They are heavier than stock, harder to control with on modern high intensity lobes.
Doing some research now that you have said that - I do see people have problems with them floating the valves... Wonder why that is?? I was under the impression they were lighter than stock from the description on Comp's site:
COMP Cams® has been a major proponent of steel rockers arms for many years, however with recent developments in the design and manufacturing of aluminum rocker arms, it is now possible for us to offer a premium aluminum rocker alternative. COMP Cams® proudly introduces the new “Gold Standard” in stud-mount, aluminum roller rocker arms – the Ultra-Gold™.
• The most advanced aluminum rocker arm ever; incorporates modern design features
• Lifetime warranty - buy them once, use them for a lifetime
• CNC-machined, lightweight design yields unrivaled quality & ratio accuracy
• Additional clearance versus competitors – clears most popular performance valve springs
• Proven to withstand extremely aggressive spring pressure and valve lift
Guess it wouldn't make sense for them to say they are crap on their site tho, eh?
This thread is getting a bit long, but still a good read.
https://ls1tech.com/forums/generatio...rformance.html
People seem to be pretty happy with these guys.
Super Hulk Smash
The stock rockers are very light over the valve. Roller rockers are not.
PAC did some spintron testing on a roller rocker vs stock. They didn't disclose the rocker, but the stock rocker went out of control 2000 RPM later than the roller rocker with similar spring pressures. You have to have a lot more spring pressure to control them as well as stock. The problem is, they are aluminum and don't like those pressures for a long time. That also wears everything else.
Now, the stock rockers have some issues like side loading the valve which is bad with bronze valve guides (which I think is overplayed based on first hand testimony) and they scrub the valve tip pretty good over .630" lift (which is a real issue).
I'd look for endurance lobes with healthy lift (.590-.620 range) so you don't loft the lifter and destroy the lifter/rocker/cam from the thrashing and run stock rockers w/trunion upgrade (to alleviate the one known issue - spilled needle bearings), lightweight valves for easier valvetrain control, good lifters that can take a beating, and stiff pushrods (stiffer than the 5/16" spaghetti noodle **** everyone tries to sell - again spintron testing shows it's not nearly stiff enough).
