aluminum 5.3 question
You could pull the crank sensor and look in the hole. 58 and 24x wheels have a distinct difference. Google some pictures of 2 side by side and you should be able to tell just looking thru the hole.
10 mm bolt holding the sensor in. Just don't lose any shims that might be between the sensor and block.
