figuring static compression
Old 08-14-2013, 08:39 AM
wells01's Avatar
Default figuring static compression
when figuring static compression ratio, does the distance from the top of the piston to the top ring need to be took into account? Im building a 408 and I thought I was done figuring compression until I read something about this. I used the compression calculator from the csgnetwork.com website which I've
seen its used alot by other people on here.
my specs are
CID-408
Bore-4.030
Stroke-4"
Rod Length-6.125
Head Gasket Bore-4.060
Head Gasket Thinkness-.040
Head Chamber Volume-64cc
Piston Dome Volume-wiseco -3cc flattops
Deck Clearance-0
Using the compression calculator mentioned above I get 12:1 which is what I want, but now I'm unsure.
Old 08-14-2013, 08:50 AM
PREDATOR-Z's Avatar
My calc gives me 12.09:1 with the info you gave.
Old 08-14-2013, 09:05 AM
wells01's Avatar
ok, yeah I seen another calculator that asks for the dimension from top of piston to top of first ring, so I would think that would make the compression come out lower if that had to be figured in. The guy that done my machine work figured for me and came up
with the same thing. I guess most dont use that dimension, just makin sure I actually end up with the ratio I want.
Old 08-14-2013, 05:29 PM
RezinTexas's Avatar
In my calc the area above the top ring was about 2% of the clearance volume. Kinda insignificant, but if you are very detail oriented then it can be considered.
Here is the link to the calculations explained: http://www.scribd.com/doc/145057435/...RAFT-01-Jun-13
Old 08-14-2013, 05:35 PM
427zm's Avatar
Rezin, this is both awesome and ridiculous all in one. Your signature should always be followed w/ UATD - "Ultimate attention to detail"
Old 08-14-2013, 11:00 PM
SOHCNightmare's Avatar
This is great. Bookmarked
Old 08-15-2013, 04:39 AM
RezinTexas's Avatar
my specs are
CID-408
Bore-4.030
Stroke-4"
Rod Length-6.125
Deck Clearance-0
using the top ring volume, I get 11.85:1. Without using it, I get 12.08:1. Here are my assumptions for info that you didn't give:
Top Ring Land thickness (T_RL) 0.295"
Top Ring Land diameter (D_RL) 3.971"
thanks man
Old 08-15-2013, 07:42 AM
wells01's Avatar
yeah im not sure on the above the ring specs. my shortblock is already together and now i have this to think about lol. i may call wiaeco today and see if they can give me the specs.
Old 08-15-2013, 08:59 AM
wells01's Avatar
just got off the phone with wiseco and the specs are. thickness-.295, dia-3.976, so your right on that. so im not where I thought i was.
Quick Reply: figuring static compression
