extremly low oil pressure/ no oil pressure
Old 08-27-2013, 01:17 AM
SuperStock2001's Avatar
Default extremly low oil pressure/ no oil pressure
hey hows it going, so after checking if my o-ring on my pick up tube was pinched, looked at it, it was good, but i still took off the oil pump took it back and got another one just to remove them from the equation. what i just did was removed the transmission. and also the rear cover oil came out from there and i can see the crank. one of my friends said theres suppose to be a plug there is this true? if so the max amount of time i ran the car was about an hour with about 3 pounds of oil pressure. should i take my built back to the machine shop and make them check that the bearings and such didnt get ruin? anything will help thanks. i believe where im putting the arrow at is where he said it belonged
Attached Thumbnails extremly low oil pressure/ no oil pressure-ls1-rear.jpg   extremly low oil pressure/ no oil pressure-ls-rear-2.jpg
Old 08-27-2013, 04:29 AM
Josh18Fan's Avatar
I can't speak for the picture with the black arrow pointing, but where the red arrow is pointing should definitely have a barbell plug in it. That will cause no/severely low oil pressure.
Old 08-27-2013, 04:40 AM
Quick Carl's Avatar
Barbell is missing. If it ran that long the bearings are probably toast.
Old 08-27-2013, 07:35 AM
2000ultraZ1911's Avatar
Yes bearings are probably done they say 10 psi per 1000 rpm minimum...
Old 08-27-2013, 07:45 AM
schnellttz06's Avatar
I dont think I would take anything back to that machine shop, thats a pretty big mistake. Enough to make you question the entire build. And what's with all that RTV, you just need a small amount on the corners. I think your bearings are probably ok though, im sure they have a shortened lifespan though. But apparently you didn't prime your oil system or you would have found this issue prior to even cranking it. I still have no idea why people spend all the time and money and dont get a oil pump primer.
Old 08-27-2013, 08:23 AM
KCS
Moderator
KCS's Avatar
Black arrow: no plug needed
Red arrow: barbell plug is missing
Bearings are probably hurt/worn, especially if the car was driven. If it just sat and idled, it might not be as bad. Either way, a closer look at the bearings is needed.
Old 08-27-2013, 11:24 AM
Where would I be able to buy that plug at? I never actually drove the car just turned it on to eliminate oil pressure sensor, oil pump, pick up tube o ring as the issue. But I did rev it up to 3000k and got a psi of bout 30
Old 08-27-2013, 11:57 AM
KCS
Moderator
KCS's Avatar
The dealerships would have it.
Pull the filter, cut it open, and look for bearing material. If its clean, I'd run it but periodically check the filter.
Old 08-27-2013, 01:38 PM
And do yourself a huge favor and prime it next time, get one of these
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=121166615684&ssPageName=STRK:MESE:IT
Old 08-27-2013, 05:13 PM
Yeah, I got one and it was reassuring to see oil flowing from the rocker arms, had instant oil pressure when I finally got it in the car and fired it up for the first time. No waiting on the rattling lifters to pump up.
Old 08-30-2013, 03:17 AM
chrisfrost's Avatar
2 things ,,,,,,,,why did'nt the builder think 3lbs. was a problem and the first pic the arrow is pointing to a freeze-plug. I guess You assembled and installed the engine .
Old 08-30-2013, 05:24 AM
KCS
Moderator
KCS's Avatar
That's not a freeze plug...
Quick Reply: extremly low oil pressure/ no oil pressure
