Where is my oil going?
Old 05-17-2004, 04:11 PM
theblur98ss's Avatar
Default Where is my oil going?
I have a 422 that I built last year. I put about 900 miles on it last year with no problems. This year I've put maybe 400 miles on it and I'm going through a good bit of oil. Maybe a quart every 300 miles. The car is smoking on WOT runs and after watching Taner's video my car is detonating out the exhaust after a hard run like his. I ditched the PCV system and I'm running dual breathers. I'm running cometic head gaskets and studs. Any idea or something I should check?
Old 05-17-2004, 07:37 PM
Scalpel's Avatar
Do a leak down, I'm guessing your rings are toast or valve seals are done.
Old 05-17-2004, 09:10 PM
romanss's Avatar
I agree, do a leak down.
If you're spraying, which it looks like you are watch those head gaskets.
Oil and nitrous are a very bad mix.
Roman
Old 05-17-2004, 09:19 PM
99WS6LS1T/A's Avatar
Roman
RomanSS I see that you have "home of the fastest 6 speeds". Isn't that Allan Futrals record 9.88 @ 144???
Old 05-17-2004, 09:29 PM
romanss's Avatar
trying to stir the pot???
Nope Taner has the record at 9.58, who lives in my town. Nice try though.
Roman
Old 05-17-2004, 10:49 PM
Roman
Just had to mess with you. I have to say your 6 spd. time is more than respectful!!!
Old 05-17-2004, 10:55 PM
Mike K.'s Avatar
like they said do a leakdown, might be time for a rebuild from the sounds of it.
Old 05-18-2004, 08:09 PM
This motor has a total of 1200 miles on it. It's barely even broken in. Did the rings not seat properly maybe? The motor hasn't been sprayed yet either.
Old 05-18-2004, 08:17 PM
romanss's Avatar
Man that is shitty.
I'd start with the leakdown. But it would be a lot easier to check you valve seals.
Good luck,
Roman
