Valley Cover Help
Old 11-04-2014, 01:49 PM
El Hundo's Avatar
Default Valley Cover Help
I have a 02' LQ4 which has been bored .065 over so running all LS3 internals. Pistons, rods, even crank (58x), as well as heads (0821) and an LS3 intake.
From my understanding I have to relocate the knock sensors from the valley cover to the side of the block, correct? Question is with the crank change to 58x, and LS3 front cover (pn# L200010106) which relocates the cam position sensor, which valley cover should I go with: LS2, LS3 or can I reuse the LQ4?
Old 11-04-2014, 07:00 PM
S10xGN's Avatar
Only the early style will fit. There are two different ones depending on the PCV setup, but both will have the knock sensor towers. Basically reuse the one you have, but you should plug the knock sensor holes so trash doesn't get in there...
Old 11-05-2014, 11:39 AM
El Hundo's Avatar
Cool, thanks! So upgrading to the newer style with the breather spout isn't actually necessary?
Old 11-05-2014, 08:38 PM
S10xGN's Avatar
Depends on your emissions laws and if you'd rather run VC breathers than a PCV system. The later cover is better for PCV but both can work...
Old 11-05-2014, 09:04 PM
That's MISTER MODERATOR
Paul Bell's Avatar
The knock sensors can stay in the valley-I believe they work better there anyway.
I suggest you go with the LS6 valley cover with the integrated PCV stuff.
Old 11-06-2014, 07:19 PM
S10xGN's Avatar
Paul, will the early knock sensors work with the 58x wheel & ECM? I (like the OP) was under the impression they needed to be swapped to the later style...
Old 11-06-2014, 07:53 PM
El Hundo's Avatar
Good question!! Another thing I need to know...
Old 11-06-2014, 09:35 PM
Paul Bell's Avatar
I gotta find this EFI book I have that has this info......
Old 11-07-2014, 12:48 AM
Youngblood16's Avatar
I don't believe so, there are adapters to adapt the LS1 harness to accept the LS2 and newer knock sensors.
Old 11-07-2014, 09:08 PM
S10xGN's Avatar
Yeah, but isn't that made for people that are swapping to the later (58x) engines and ECM's while keeping their harness intact? The only experience I have is with a carb'ed LS1. Nothing EFI yet, but I do read a lot. And no, I didn't sleep in a Holiday Inn last night...
Old 11-07-2014, 10:45 PM
Paul Bell's Avatar
The 24x knock sensors are single wire, resonant type.
The 58x knock sensors are two wire flat response type.
You'll need the two wire type. They bolt on the outside of the block with a through bolt. Cavity A, blue wire, signal. Cavity B, gray wire return.
You'll need to install dummy 24x knock sensors in the valley to get the valley cover to seal around them. OR you can somehow fab up a closure for the knock sensor holes.
Quick Reply: Valley Cover Help
