Trick flow 215's on my ls1 383 ???
I have a Lunati 383 kit I will be Using for my 383 LS1 Build , Also have Fast 102/102 , Pat G Specd Cam ( do not have yet so no specs ) .
Looking for anybody Using this setup with #'s HP & Torque Please with The Trick Flow 215's 59cc . Maybe Pat can chime in since he will be Spec n the Cam ...I can get the heads for $1500 with a set of Comp 1.7 Rockers .
Thanks for any Help & Input ....This will be going in my "72 SS Camaro with a 6 Speed & Full 3" Exhaust , no Cats .
A friend of mine has the prc 2.5 243s from texas speed. Never upgraded the intake or throttlebody and is running LS1 pieces. He has a really aggressive cam though. He made 420/430. Yours should be more than that with that Fast
Depending on the dyno, I'd say those heads are capable of hitting that number, as long as they are paired with good parts and the right cam profile to take advantage of the heads flow characteristics. If I were you, I'd be looking to run maximum compression on that setup too. More compression means higher HP and TQ numbers throughout the RPM range.
Heads are at 59cc rt now & will stay there , I know Chris 1313 made a Lil over 500rwh thru his 4l60 with a 102 setup he Ported to match his TF 215's ....he is at 57cc & I Really don't want to go quite there . I am Looking at around 11:75 on my Compression with the Parts I have .
My Filter Setup is an AirRaid 2008 Z06 7ltr ...Straight in !!!have to post pic off my phone .
