Cam Questions
Cam Questions
Hey guys Im wanting a cam really soon but I have a questions
I have a 2002 Z28 Camaro A4
What are some good cams that are still streetable?
Is the MS3 streetable ?
If I was to go LS1 Hot Cam would I need a Stall since it's a small Cam ?
Is there a Good cam that's Between the hot cam and MS3 ?
Umm H/C/I THATS about it motor wise
Is it a A4 ?
Although I wouldn't consider an MS3 with a 3800 stall "streetable". Can it be driven on the street with relative effort? Sure. Would it be fun to drive more than just when racing on the streets (eg. driving to work or to the store)? Not really.
Okay my bad guys Im looking into to putting in
-92mm Fast Intake
-Ported LS1 Heads
I can't figure out which cam to go with, I want to keep it streetable
-92mm Fast Intake
-Ported LS1 Heads
Alright man thanks. Did you change anything in the Valuetrain
Keep duration in the 22Xs to low 23Xs. It's easiest to find a sponsor you like and call them for some advice. I've used both EPS and Cam Motion with great results. Martin from Tick is also very helpful here.
MS3 shouldn't even be on your mind. It's more towards the max effort side of things and would need a 4000 stall, short gears, and a perfect tune to work well. If you like Texas Speed they have dozens of other cams more suitable for your combo and goals.
