Reverse Dome vs Flat Tops in an NA Build
Just spurring some debate...
In an Naturally Aspirated motor, I realize there is some debate as to whether a dished piston is less than ideal for the flame front due to a lack of a quench area. However, the reverse domes with quench pad areas that mimic the combustion chamber seem like a good compromise. Does anyone have any data or real world experience with the difference in power (if any) between a reverse dome and a flat top?
If you're following my other current thread, you'll see that I'm considering using small bore heads with a tighter combustion chamber on a bigger motor. I want to know if it'd be worth it to soften the chambers or simply run a reverse dome piston to get compression where I want it.
When the Busch series went from V6s to 9:1 V8s...they did not use a 76cc chamber and a flat top because the flame travel was smooth and even.
They quickly used a reverse dome and like 38cc chambers with 18 and then 15 degree heads
This combo magnified the compression turbulence and lowered the BSFC numbers
What heads are you considering for a small-chamber? I'm certainly not that knowledgable on the options out there, but I haven't stumbled onto any small chamber LS heads, outside of the C5R head.
What are the options for this type of combination? It's funny you started this thread, because I have wondered about this exact topic myself...
Usually the opposite. A dish has little to no quench area. Not really a big issue with FI as the boost aids the mixing.
I'd have to say that a reverse dome logically makes more sense in your case Jake. I'll probably be in the same boat once I swap out my bottom end. I'll probably have the Mamo 220's for a long time.
