How much am I leaving on the table
Old 08-18-2015, 09:11 PM
98z28jorge's Avatar
Default How much am I leaving on the table
Ok I just finished my build and wanted to know you guys opinion as to how much I am leaving on the table using my patriot 5.3 heads and ls6 intake on this build as to other heads and intake options
It's a aluminum 6.0 with 4.005 forged pistons and rods stock crank
Patriot 5.3 heads cr 11.2:1
Lsr 231/239 cam
Ls6 intake
Hooker lts 1 3/4
Open tsp y pipe for exhaust
Stock 10bolt 3.73s
Performabuilt 4l60
3800 stall
Nos plate 150 shot
Don't have any dyno # just track results it should be around 3500 with me in it
Ran 11.5@117 na was hoping for low 11s @ 120+ it was very hot and humid tho here in south Florida about 93degrees and 10.26@131 on the 150
Any input would be appreciated
Old 08-18-2015, 09:18 PM
redtan's Avatar
Better heads and FAST 102 can easily get you 40-50rwhp on top of that stuff.
Old 08-18-2015, 11:19 PM
NAVYBLUE210's Avatar
Location: Coast of San Mateo County Between Pacifica & HMB
Good results for your combo!
RedTan is right MMS220s + MAMOFIED FAST 102 at least 50 Maybe
60 more HP!
Old 08-19-2015, 03:49 AM
HCI2000SS's Avatar
I saw a test a while back where they compared the 5.3 heads to some high dollar Trickflow heads and there was like a 20 hp difference
Old 08-19-2015, 04:39 AM
96capricemgr's Avatar
Which 5.3 heads?
Old 08-19-2015, 05:19 AM
HCI2000SS's Avatar
PRC 5.3 heads
Old 08-19-2015, 05:31 AM
98z28jorge's Avatar
It would be like $3000+ for 50hp I think I will just keep upping the nitrous shot and be done with it Thanks for the input guys
Old 08-19-2015, 05:43 AM
HCI2000SS's Avatar
This has always been my line of thinking as well. If $3000 heads are only getting me another 20 hp over $1500 heads, I'm then much better off spending $10 on some nitrous jets and upping the shot and gaining the same hp if not more. To each their own though
Old 08-19-2015, 06:55 AM
redtan's Avatar
The same can be said about any mod really. Why spend $700 on a set of headers for 30hp when you can spend the same kind of money on a nitrous kit that gets you 150hp? Why add a cam for $1500 afterwards when you can just buy a $10 jet?
Why did you spend all that money on the mods in the sig when for 1% of the price you could've gotten new jets and got the same power?
If the OP wants to maximize his N/A potential then that's the kind of money he has to spend? Is the the best bang for the buck overall? No, not when you're comparing it to nitrous.
Old 08-19-2015, 07:18 AM
98z28jorge's Avatar
I had a sbe ls1 with the patriot 5.3s on it and a 228r cam before and it ran good actually better than this new setup it trapped 95 mph in the 1/8 to the new cars 93 mph but it also weighed 200lbs less and it was in like 65 degree weather so I think this one might do better in better weather and new setup really picked up on the nitrous so it's give and take it will end up on a 300hit anyway I just wanted to know how much more I coulda gotten from it na
when I was building this new setup I had the chance to get slightly worked l92 heads but sence I already had the 5.3s I said screw it and used them and was told the 5.3s were gonna hold the 6.0 back some
Old 08-19-2015, 07:55 AM
HCI2000SS's Avatar
Here's another way to look at it...with the same top end and everything else on a 408 vs the LS1 horsepower will be almost the same but the torque will be quite a bit broader on the 408. Since you have more cubes here you can run a bigger HCI than you could with the LS1 while still retaining the same drivability. The better heads will only add one part to the equation.
There's really no wrong answer here. It's just in all how much power you want, how you want it and how much you want to spend for it.
Old 08-19-2015, 08:05 AM
farmington's Avatar
what about cnc LS3 heads and a fast intake
Old 08-19-2015, 08:34 AM
redtan's Avatar
Would make a helluva lot more power than the smaller 5.3s, especially on the juice. Might be lazy down low depending on the compression, but up top while spraying it will fly.
No need for the FAST intake especially with nitrous.
Quick Reply: How much am I leaving on the table
