Wire brush on end of oil plug
Old 11-01-2016, 01:38 PM
Jacob Paisano's Avatar
Default Wire brush on end of oil plug
I have low oil pressure at idle,so i changed my oil and found this (i can make a wire brush).
Rebuilt motor with 10,000 miles on it,this is the 3rd oil change. Any ideas before i tear into it?
2002 camaro ss ls1
Old 11-02-2016, 06:47 PM
truckdoug's Avatar
damn thats not good
Old 11-03-2016, 03:59 AM
Jontall's Avatar
Comp trunnions can cause this if you have them installed. Or maybe the cam retainer plate is being worn-away by the cam gear.
Old 11-03-2016, 07:12 AM
ls1charged's Avatar
what about trunnions would cause this?
Old 11-03-2016, 02:05 PM
Jontall's Avatar
Old 11-03-2016, 02:10 PM
ls1charged's Avatar
is this caused from fitment issues when pressing?
Old 11-03-2016, 05:21 PM
itsslo's Avatar
Pretty sure it happens on all of them.
Old 11-03-2016, 11:50 PM
ls1charged's Avatar
wow! good to know as i was contemplating doing the swap
Old 11-04-2016, 12:07 AM
LLLosingit's Avatar
When the trunion wears it happens rather slowly and it's fine metal from everything I've seen posted, Most people didn't even notice metal in the oil/filter during oil changes and didn't know they had a problem until disassembly.
Old 11-04-2016, 02:37 PM
Jontall's Avatar
I'm running the bronze bushed rockers now and no problems. Struab has them and Tooley too.
Old 11-05-2016, 09:01 AM
Old Geezer's Avatar
Default Pretty sure....
That's
Old 11-05-2016, 09:03 AM
Old Geezer's Avatar
Obvious it's shards, and not fine particles.
Lifters/cam issues?
Old 11-06-2016, 09:44 AM
corvet786c's Avatar
, its the cam retainer plate, if you had not drilled small holes in it for it to be lubed better. LS1 are known for this defect. This is what happen to mine. Needed a new motor.
Quick Reply: Wire brush on end of oil plug
