Please identify this cam for me.
Old 07-04-2004, 01:00 PM
FILE's Avatar
Default Please identify this cam for me.
Just like the titie says. All I know is that this cam is made by Comp Cams just not sure which it is.
Old 07-04-2004, 02:16 PM
Grimes's Avatar
I tried using their online database, but couldn't get the right #'s. I would just call their tech support up...
Old 07-05-2004, 10:39 AM
FILE's Avatar
Thanks.... Anybody else wants to give it a shot?
Old 07-05-2004, 11:37 AM
CHIEFMB2's Avatar
all I can see is that it is hydraulic roller and the lobe separation is a 114+4. I don't know what the other numbers are.
Old 07-05-2004, 12:28 PM
McRat's Avatar
All the listed LS1 lobes are 37xx, not 33xx. Custom lobes? Dunno.
Old 07-05-2004, 04:36 PM
Unaffliated Racing's Avatar
it's 212/218 .553"/.561" 114+4
those are small block chevy lobes, but they are on an R master because of the 2.165" LS-1 bearing journal size....they are almost identical as far as aggressiveness as the lobes specifically designed for LS-1's
Old 07-06-2004, 01:18 AM
Dueledaily's Avatar
MTI would be able to tell you, they have a machine made for that kinda stuff.
Old 07-06-2004, 01:29 AM
BOWTIE's Avatar
Sounds like he got it. If I remember, I will check the catalog when I get home in the morning.
Old 07-08-2004, 07:09 AM
Old SStroker's Avatar
Yep. Xtreme Energy HR lobes on a 114 LSA. The higher lift versions would be 31XX's.
FWIW, +4 means 4 degrees advance ground in.
