KD tools valve spring compressor
Old 07-29-2004, 09:45 PM
chris2000ss's Avatar
Default KD tools valve spring compressor
do you guys know if this spring tool will work with dual springs??I thought I read somwhere that they only worked with single springs...I'm doing a spring swap soon and need to know if it will work...
Old 07-30-2004, 09:55 AM
1fastWS6's Avatar
nope, won't work.
Old 07-30-2004, 10:03 AM
Originally Posted by 1fastWS6
nope, won't work.
what type of tool do you suggest I go with???
Old 07-30-2004, 10:10 AM
Sharky's Avatar
I used Vinci's (Crane) tool for my double spring swap. It worked really well.
Made switching two springs at the same time a snap.
Old 07-30-2004, 10:37 AM
1fastWS6's Avatar
Make your own. Took me 10 min and about $1 worth of steel bar stock. I haven't found a tool yet that works any better (that also doesn't cost $100+).
Old 07-30-2004, 11:38 AM
kenkaru's Avatar
you can modify an autozone crowbar type compressor to work well. I made a jpg with pics and instructions. pm me with an email address and I'll send it to you
Old 07-31-2004, 09:21 PM
thanks for the replys guys..I think i'll look into making my own and save some $$$..as some of you suggested..
Old 07-31-2004, 09:27 PM
HumpinSS's Avatar
Vinci tool wins hands down
Old 07-31-2004, 09:33 PM
where can I get one??
Old 08-24-2004, 08:53 PM
mrr23's Avatar
http://www.vincihighperformance.com/...TS%20PAGE.HTML
Old 08-25-2004, 12:05 AM
God of Thunder's Avatar
i ended up having to make my own for my swap. worked better than any of the other tools i was trying. you might want to consider it
Old 08-27-2004, 03:23 PM
Joe Vinci's Avatar
Vinci "VHP" valve spring tool available on web www.vincihiperformance.com Beware of home made lever type tools. They place serious load on the pivot bolt or stud boss and can bend small daimeter valves and crack valve guides.
Old 08-27-2004, 03:28 PM
Lucian's Avatar
i bought the KD tool and it would not work, then i bought the vinci's tool and it worked great
Old 08-28-2004, 03:54 AM
busavette's Avatar
I used a KD tool to put patriot duals on my heads with no problem,the heads were off the car.
Old 08-28-2004, 05:34 AM
99ls1guy's Avatar
this is what i did. worked perfectly for me. im glad i didnt waste my time or money on the other tools
Old 08-28-2004, 09:13 AM
Lucian's Avatar
I must say that i am very impressed, I could not keep the inner spring in. In fact, one time I was trying to tighten it down and it just blasted off and hit me right in the eye (luckily i wear glasses and unfortunately they are expensive). So i took a said a few choice words, threw the tool, and took a break. Came back 5 minutes later and still couldnt get it to work. I spent of a total of 2 hours trying to get it to compress the dual springs . So i said forget it and ordered the vinci tool . The only complaint i had with it (vinci tool) was that fact that it is black and all of it comes off after the first couple of springs.
Dont get me wrong, the KD tool is a great, inexpensive tool for single springs, but i couldnt get it to work on the duals.
Old 08-28-2004, 09:16 AM
Lucian's Avatar
I bought one of the generic valve spring crowbar type spring tools to cut off, but i was afraid i was going to break a bolt off. So, i just decided to pay the extra money for the correct tool for added insurance.
Old 08-28-2004, 05:31 PM
99ls1guy's Avatar
i thought they meant it risks breaking off a bolt when using it to pry. either way, i had good luck with it.
Old 09-01-2004, 01:09 PM
z-ya's Avatar
If you use a 8mm stud and nut arrangment on the homemade tools you won't break a bolt off or stress the threads in the head .
Quick Reply: KD tools valve spring compressor
