just got new cam and springs want to replace timing chain ??
Old 08-06-2004, 09:24 AM
Justin98TransAm's Avatar
Default just got new cam and springs want to replace timing chain ??
My engine now has over 100K miles on it and still the same timing chain I'm doing my cam swap, so I'm going to also do my chain, which one should I go with? i'm Running a Vortech 9lb kit, with long tubes, 220/226 .564/.569 -114+4 918 springs and titanium retainers.
Old 08-06-2004, 10:37 AM
ThackerSS's Avatar
Being a 98 I would go ahead and throw on a new one. If you have the money to do everything else... buying a little insurrance never hurts.
Old 08-06-2004, 11:03 AM
Boostaholic's Avatar
While your doing the timing chain you should do a ls6 ported oil pump too, you can pick one up for approx $140
Old 08-06-2004, 01:55 PM
YOOFORMULA's Avatar
I just installed a Rollermaster double roller chain/ported LS6 oil pump in mine both went on pretty easy but I did have to machine my old ASP pulley for clearance.
Old 08-06-2004, 02:26 PM
DrkPhx's Avatar
I used the GM heavy duty chain and dampner which will bolt right into a 98 block.
Old 08-06-2004, 04:42 PM
you got a part number for that by any chance?
wonder if I would have to machine my Vortech Crank Pulley if I did the LS6 ported oil pump
Old 08-07-2004, 01:23 AM
DrkPhx's Avatar
1. 88958608 – “New” Gm heavy duty single-row Timing Chain…..
2. 88958607 – GM timing chain torsional dampener………………..
Old 08-07-2004, 01:25 PM
01_SuperSlow's Avatar
JWIS chain
It's used in the C5R engines, 'nuff said
