LS6 "style" heads?
LS6 "style" heads?
Do all aftermarket LS6 heads begin life as GM LS6 heads or do the companies cast their own. Take THESE for example. Are they true GM heads with added goodies, or are they made by Patriot Perf. from scratch?
damn, jrp answered w/o saying to go search?
AFR is the only company SO FAR that casts their own heads. edlebrock/linghenfelter are currently R&D'ing their own castings as well. PP's LS6 style head is a great bang for the buck, it flows pretty well, and its cheap(as performance heads go). however as more cars get LS6 castings stock, the LS6 castings should go down in price(as they will flood the market, won't be such an exsclusive item). also the competition provided by edlebrock should help with prices as well(i'm hoping anyway).
i just got off the phone with a guy from PP and we talked about the LS6 style (LQ9 heads) and he said it was basicly the same as the LS6 head but with bigger combustion chamber BUT that they could do that head in a 64 or 58 or 59 i think if you want
so im assuming that it is every bit as good as the LS6 head if they can bring the comustion chamber back to the same size as the LS6
he said that hey dont shave the head to do it but rather build the chamber up and then use the cnc machine to machine the combustion chamber to whatever it needs to be
Originally Posted by taqwache
how would they blend in the welds with out a little surfacing tho. i just bought some used ones my self and after cleaning them up, you cant even tell that they are welded. although you can see that they have been CNC'd with the lines it leaves.
We begin with a GM OEM LQ9 raw casting. These castings are +.050 on deck hieght. We then weld up these heads, heat treat to OEM specs, and machine them. During the machining process, .040 is taken off the deck. This leaves us .010 to mill for clean up after our CNC work is finished. This makes our process unique in that after all of our maching and CNC work is done, our heads are still at the factory deck hieght. No other company using GM castings can achieve this.
We believe that with our free MLS 6.0 head gaskets and new head bolts included with every set of heads, that our products give you the most power gained per dollar spent!!
Originally Posted by cyphur_traq
taqwache, didn't you get pdd's vavlve damaged set? how bad was the damage? seats have to be reworked or anything?
steve
yup, those are the ones. they had a few bent intake valves but i am replaceing all of them with new ferra intakes. the exhuast are still ok. all the seats will need to be machined to seal the valves and while i am at it, going to have the exhuast done also. also going to smooth out all the ports to a race type finish, deshroud them to a 4" bore, replace the springs with cranes and put in new seals. i am not sure which springs it has but if they are the golds the gold finish must of come off. eather way there getting replaced for safety. for the price, it was a very good deal
steve
steve
You should consider putting the golds on it. They are one of the best on the market!! Complete kit with ti keepers, super 7 locks, viton rubber seals, and bases for only $295.00.
another question. could you tell me what kind of springs these heads have on them. they were bought in november last year.
thanks steve.
why don't you like the gold finish? i think they look kinda pimp
pdd bent the valves b/c he mis-shifted and over-revved the engine. he had installed an different shifter i do believe, and on the way to work he was playing around and was not used to it, resulted in a missed **** = overrevved motor = kissed pistons. you can ask pdd, but i think thats pretty much what happened. but i understand what you meant now about the gold coming off. i didn't eat my wheaties this morning, so i'm a little slow today.
i already have the ti retainers, locks, and bases. do you sell the springs by them self for less. the reason i was going to use the cranes was because i already have them on my car right now and have not had any problems with them. also there only 4 months old.
thanks steve.
thanks steve.
The springs were crane duals.Call me,I can get you just springs that will work with your current retainers and seat bases.
thanks steve.
thanks steve.
I believe you would be much happier with our custom designed, race-proven .650" golds than with an "off the shelf" spring.
I have a spring that will work with your current locks,retainers and seat bases.Contact me for more information on what springs that will work with what retainer.
