Are 99 pushrods the same as 00 pushrods?
I'm going to pull my valve coves and check to see what my pushrods look like as i've been noticing a slight miss and tick ever since I went 4th to 1st on the highway about a month ago
My buddy has his pushrods out of his 99 Formula from when he swapped his G5X3 in with TR hardened rods. He also has some newer ones with like 1K miles on them from when he did the same misshift, so i'll use those up first. If I find some bent up stuff, will the ones from his 99 work fine with my 00? I'm assuming they will, but I just want to make sure before I tear the car apart.
They should be the same unless one of the cars has been modified to where the head was milled or basecircle of the cam was different for some reason, if you really want get calipers and mesure them.
Originally Posted by DMNSPD
About a month ago I raced a CTS-V on 220..
Originally Posted by chris2000ss
you can have my p-rods after this weekend who won the race??? i'll stop up @ A&A later and pick up the parts I ordered...
And your stuff should be here any time.
