232/230 580 110 LSA Cam Questions??
Originally Posted by DAPSUPRSLO
That is exactly what I was thinking.
Originally Posted by GrannySShifting
Reed Cam lobes?
Guessin its a really lazy lobe?
i be interested in seeing thsi vs your B1 cam. even the B1 cam is a lazy lobe
Originally Posted by jrp
what was the ICL and duration @ .006?
Duration @.006 284/282
Duration @.050 232/230
Duration @.200 144/143
Lift was .578/.578. LSA was 110 and I ran the cam at 108icl and 106icl. 108 gave the best numbers.
6600 rpm clutch dump of death Administrator
Originally Posted by gomer
Here's the specs that I have written down off that cam
XE lobe 3756
Duration @.006 286
Duration @.050 232
Duration @.200 144
Lift @ 1.7 is .541
XE-R lobe 3719
Duration @.006 285
Duration @.050 232
Duration @.200 148
Lift @ 1.7 is .575
XE-R lobe 3718
Duration @.006 283
Duration @.050 230
Duration @.200 147
Lift @ 1.7 is .573
Other than lift, all the specs on the comp lobes vs your lobes on the intake side could be within grind specs for the mfg.
So, are you saying on your combo the B1 (221/221 114) made more power than the 231/237 and Chris' grind? By power do you mean dyno numbers, or track time?
Was your combo optimized for those cams?
Originally Posted by J-Rod
XE lobe 3756
Duration @.006 286
Duration @.050 232
Duration @.200 144
Lift @ 1.7 is .541
XE-R lobe 3719
Duration @.006 285
Duration @.050 232
Duration @.200 148
Lift @ 1.7 is .575
XE-R lobe 3718
Duration @.006 283
Duration @.050 230
Duration @.200 147
Lift @ 1.7 is .573
Duration @.006 286
Duration @.050 232
Duration @.200 144
Lift @ 1.7 is .541
XE-R lobe 3719
Duration @.006 285
Duration @.050 232
Duration @.200 148
Lift @ 1.7 is .575
XE-R lobe 3718
Duration @.006 283
Duration @.050 230
Duration @.200 147
Lift @ 1.7 is .573
Btw... I never said that Chris had anything to do with the grind I was just given the cam to test by Patriot and after I got the data I took it out and gave it back to Patriot.
The 231/237 made the most power out of the three. The only thing I changed between the 3 cams was A/F tuning.. all other components were the same. None of the 3 cams were ever ran at the track due to my car having a 10 bolt rear at that time. I'm not at work today and my runview along with all the dynojet run files are on my office PC. I'll post up a comparison graph tomorrow.
Here's a graph of the patriot cam, F13, and B1 all together. All of these runs were dyno'd the same way.. except I had 3.42's with the patriot cam and 4.10's with the f13 and B1. Open cutout and all belts on the car. I can't find the 231/237 run files right now... but I'll keep looking.
It is hard trying to select a CAM. I want low end torque but like the HP also.
Thanks,
Bill
Bill
Originally Posted by Bill Bowling
Do you have the numbers for the cam you have: Precision Race Components 225 Cam??
Bill
Bill
Here's a graph of before and after the 12 bolt swap. This is using the PRC heads and the PRC 225 cam.
Thanks Gomer.
Bill
I like the smooth curve that cam puts out. How does it idle? Is this car a daily driver or just for the track? How do you think this cam would work in a daily driver car?
Thanks Gomer.
Bill
Thanks Gomer.
Bill
