4in stroke crank in a LS1 5.7 block
Old 10-03-2004, 11:55 AM
SSPerformance's Avatar
Default 4in stroke crank in a LS1 5.7 block
after sitting downn and see what i want the car to do im gona go with a stroker motor. Im new to the LS1 scene (had a LT1) I assume when u do a stroker motor in a LS1 you have to do all the same clearnacing as a LT1 or SBC rite ?
Old 10-03-2004, 12:02 PM
jerflash's Avatar
no i dont think you have to do any with a 4"
with a 4.125" i think you have to clerance the #8 piston
Old 10-03-2004, 12:08 PM
to go with a 4in bore u have to Re-Sleve the block rite
Old 10-03-2004, 12:13 PM
jerflash's Avatar
or buy a new ls2 block from sdpc
Old 10-03-2004, 02:25 PM
nah i dont want a ls2 block
Old 10-03-2004, 03:12 PM
jerflash's Avatar
y not ????
Old 10-03-2004, 03:14 PM
2MuchRiceMakesMeSick's Avatar
Probably price...
Old 10-03-2004, 03:17 PM
jerflash's Avatar
1000 is not bad and 1500 less then a sleeved block and no worries about droping a sleeve
Old 10-03-2004, 03:42 PM
cyphur's Avatar
not too many people have dropped a Darton MID sleeve.....unless they were REALLY trashin their motor. but do you know if anyone has sonic tested an LS2 block yet for bore limits?
Old 10-03-2004, 03:50 PM
I have a LS1 block already. i will be buying a eagle 383 rotating assembly for it real soon. I just wana no if there is any clearancing that needs to be done for a 4in stroke crank
Old 10-03-2004, 04:08 PM
jerflash's Avatar
oh in that case no
Old 10-03-2004, 04:12 PM
So let me get this stright There is no clearancing needed for a 4.0 stroke crank how much bigger can u go befor you need to clearance the block
Old 10-03-2004, 04:19 PM
jerflash's Avatar
4.125 you need to clerance the #8 piston a lil bit
Old 10-03-2004, 04:30 PM
LT1Burnout's Avatar
i would contact the manufacturer and ask.. to make 100%sure.
Old 10-03-2004, 04:44 PM
Atleast it keeps machine work cost down
Old 10-03-2004, 06:02 PM
Beast96Z's Avatar
I think it depends on the crank, but my 4" Callies crank required clearencing of the block on all cylinders. If you get diamond pistons, the #8 piston should be clearenced already. Once again, APE can answer all these questions and prolly give you the best deal on a complete motor so you don't have to worry about any of it.
Old 10-03-2004, 06:36 PM
i will be runing a eagle 4in crank if this helps
Old 10-03-2004, 08:10 PM
Grimes's Avatar
Like the others said before, there shouldn't be any problem w/ block intereference, but you have to watch for piston clearance for the reluctor wheel.
Old 10-03-2004, 08:34 PM
VSGLS1's Avatar
Double check the reluctor wheel. The windage tray might need to be spaced away from the crank. Just double and tripple check everything.
Old 10-04-2004, 08:23 AM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
A 4.000" crank in a 5.7 aluminum block generally = notching the block. On the iron block you generally don't have to notch.
Thanks
