newb stroker questions
I have a 98 z28 and I'm trying to figure out the best way to keep the alum. block, but beef it up. I don't want to resleeve, it's a little pricy on alum. blocks, what's the biggest stroker kit available without resleeving? I searched the forums and all it was doing was making me more confused, any help would be appreciated
-erik
-erik
also, I want to start out all motor... get over 500 on pump, get another daily driver, then begin the real fun would that be safely attained with the 392, I need something somewhat reliable...
I agree with JRP...I spent $10k on mine. 480rwhp/440tq 92 octane
You have a choice on what quality parts too..you can get the shortblock for around $6k assembled from a bunch of places including APE, More, LS1SPEED etc. Check their web prices...talk to them You wont save much putting it together yourself til you buy all the tools/gages/misc ****.
Then you need good heads and good cam/timing set/valvetrain, good intake/TB, Fuel system, 36lb injectors, clutch etc...it all adds up and you cant skimp. ~11:1 will be needed for 500rwhp, stout cam and it can still be a daily driver.
Havent run yet but hope to next weekend. Not all cars are the same or tracks...track where I run is .3/3mph slower than faster tracks like Maple Grove and Cecil but its cheap.
Im completely happy with my setup. I went the radical cam route for the sound and gave up some driveability...but its still good enough for me everyday on pump gas. I left hp on the table with LS1 heads vs. smaller cc LS6 heads and higher compression. That would have given me over 500rwhp easy but the $$ was too much for me to finish at the time. Dont get hung up on 500rwhp. A 383 or 395 with 11:1, GOOD heads, ~240 .600 lift cam, LS6 intake and 85mmTB, and good long tubes will get you there tuned right. None of those are extreme. That will cost you $9k of your $10k.
dumb question...
http://www.dallasexportsales.com/RALS1408.htm
does that not need sleeving? further more... as far as being stable, how is the 395? anyone have one? the 408? anyone?
Originally Posted by burritoboy9984
dumb question...
That looks like the Lunati 408 kit to me (Part number and pricing). Yes, it would require resleeving the block. The $3415 is only for the rotating ***'y parts. Add about $2500 to that kit for sleeves and machining. Also, at that point for about the same cost you can go up to 427. I was thinking about doing that at one point, and I might later on down the road unless the guys at Lunati talk me into their 454 LS1 rotating ***'y
David
