What makes 1 sponsor's LS6 ported oil pump different from another?
Also, why is it so popular? (used by many of the sponsors) Does anyone make an aftermarket unit? Whats the difference between the LS6 oil pump and the LS1 oil pump? Lastly, whats the difference between a ported LS6 oil pump and an unmodified one? Thanks.
Why?
Quoting jMx's website:
"Why change out my oil pump?". Well, there are 2 reasons for this. First off, it seems a lot of the 2000 and before oil pumps have an issue that causes them to totally lose pressure, which then causes your motor to tear itself up due to lack of lubrication. Secondly, some people like to have a bit higher oil pressure than stock just to be on the safe side"
Yes, Melling. The only difference is that the oil pump housing is made of iron instead of aluminum. It makes it more resilient to engine torques and variances in stresses, but not really proven a necessity over the aluminum housing ones (all the other stock ones). We have LS1s putting out over 1000 RWHP running the regular oil pumps (stock housing and internals).
Difference in the LS1 and LS6 pump?
Nothing.
Difference b/w ported and non-ported?
One is ported for increased flow. The amount of flow increased is nill. Mainly the casting flash is removed from the inlet port on the oil pump making for a smooth passage for the oil to flow through. Does it help? Probably not, but it helps sell a LOT of oil pumps. Does it hurt? It can if it's not done correctly. For instance, if the machinists doesn't get the casting flash very smooth or nicks or galls the mating surface up where the oil pickup tube mates up to the oil pump inlet it can damage/ruin the o-ring that is b/w the pickup tube and oil pump. This happened to mine and caused low hot oil pressure problems.
All this info can be found if you search.
Nothing.
Well since I was going to go with the T-Rex cam, I was going to get most of the rest of the parts for the swap from Thunder Racing and wasnt sure if I should get the LS6 ported pump from them. Wasnt sure if one company's ported LS6 pump was better than the other. I know a lot of people buy the one from Texas Speed & Peformance and that is why I figured one company's could be better. Does the ported LS6 pumps that the sponsors offer have the shimmed valve spring?
Originally Posted by ramairstyle00
i sit at 40psi at idle and over 75 when driving around. its on my stock 00 oil pump with 40k miles. is that fine?
****. there. i've met my minimum message length. i hate that crap.
Nothing.
Are the effectively the same pumps?
Why?
Nothing.
Nothing.
So back to the orginal question, there is no difference between 1 sponsor's ported LS6 oil pump and another. Does anyone know what a stock LS6 pump goes for? Did they come on the 01-02 F-Bodies? If not, then what year models would I need to get it from the ZO6s? Would I be better off just buying a stock replacement or a ported one from the sponsors? I was going to get the one from Thunder Racing since Im getting most of the parts for the cam swap there anyway. Does anyone know if the shim the valve spring?
The stock LS6 pump is the same as the LS1 oil pump on '01+ LS1s b/c that's when the LS6 came out, 2001. Same pump. Vendors market it as an LS6 pump so people think they're buying a superior pump vs the LS1 version. Just marketing.
LS1/6 pump (in the production runs AFTER the pumps that failed - i.e. the pumps everyone want) part #: GM PART # 12563964 Price $59.35 from GMPartsDirect.com
They can shim it for you if you want increased oil pressure.
A lot of this info can be found by:
A) Searching the forums
B) Calling the vendors/tuners and asking
You've got over 2000+ posts, you should know that
A stock replacement is just as effective as any of the ported ones, IMO. It's a good way for vendors to make a bit more money off a tiny bit of machining to a pump. It CAN hurt if it's not done correctly as I pointed out above.
well damn...i'm glad i havnt bought my pump yet. my car only has 23,000 miles but i'm doing a head cam swap so i'm going to change the pump also. Any reason i shouldnt just buy the pump from GMpartsdirect over a ported one?
Originally Posted by Cstraub
Don't worry, in '07 won't need a ported pump, just a bigger or smaller gilmer pully.
Chris
Chris
