arp studs
Old 11-03-2004, 03:36 PM
pdd
pdd's Avatar
Default arp studs
so according to the directions im suppose to lube up all the studs and nuts with the moly lube. so i moly up the whole stud then screw it in the bolt hole in the block. now do i have to put the head on right away or can i wait to put the head on. or do i only moly lube up the part of the stud that goes in the block ,then do the other half of the stud when the heads go on?
Old 11-03-2004, 03:53 PM
Bo White's Avatar
The moly lube doesnt dry up or anything so you can wait between install time. Just mainly lube all contact point of the threads and washers.
Old 11-03-2004, 08:49 PM
SideStep's Avatar
pdd,
Put the moly lube on the top threads, not the threads that go into the block. Also, apply some to the nut and washer faces... I just did mine....
hey do you have a sound file of your Vette???
Old 11-03-2004, 09:09 PM
Beast96Z's Avatar
Actually I would think you would want the lube on the half that goes in the block to prevent any seizing and also a correct torque reading, even though it is only like 5-10 ft. lbs. When you get ready to install the heads, then put the lube on the upper portion.
Old 11-03-2004, 09:28 PM
SideStep's Avatar
Nope.
According to the instructions from ARP you put nothing on the part of the stud that goes into the block, OR as an option you can use lock-tite on the lower threads to make it more permanent... Straight off the instruction sheet that ships with them....
Old 11-03-2004, 10:03 PM
pdd
pdd's Avatar
no sound file. my cars in a million pieces how did u get yr block and pistons so clean?
Old 11-03-2004, 10:04 PM
SideStep's Avatar
I knew it was, just hoping you had a file from before you took it apart
I used WD40 and Scotch Brite green pads. The WD40 "dissolves" the old gaskets and you don't have to bare down so hard with the Scotch Brite pad.... I then cleaned up the residue with hot water and a clean towel...
Old 11-04-2004, 06:37 AM
SAM98WS6's Avatar
make sure you do the final torque pass over again after they sit for 15 minutes...I bet you will get another 1/4 turn!! Need to to it a couple times.
Old 11-04-2004, 07:52 AM
Bo White's Avatar
Ancient Chinese secret ....had to do it, who remembers that on TV?!
Old 11-04-2004, 07:57 AM
SideStep's Avatar
I do, but I am older than most here....
