Hysteria/Bo White...others
Hey guys, I was messing with the 241 casting heads that I have and started to compare them to the 853 casting that I have been practicing on. Right away I noticed the combustion chamber is drastically better done. It comes to almost a complete polished surface. As opposed to the 853 being very rough finish, probably close to 60 grit paper. The next big difference would be that the intake valves are deshrouded noticably more than the 853. It was written somewhere that the 241 flows 10 cfm more than the 853. I can see how that would be a minimum number from the basic casting differences. I think really what I am getting at is if you are a home porter, DO NOT BOTHER with '98 heads. Have any of you guys ported the 853 and 241 and had flow numbers on each? I am curious to how far off in flow they would be at peak.
Later
Brandon
Later
Brandon
The 241 casting is a very nice head,just the chamber is a good enough reason to use the 241.The whole heads finish is nicer then the 853.Its also very easy to port.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Originally Posted by FASTONE
The 241 casting is a very nice head,just the chamber is a good enough reason to use the 241.The whole heads finish is nicer then the 853.Its also very easy to port. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Yes, the 241 is a nicer looking cylinder head from the casting procedure. I believe it is diecast, also the 853 cobustion chamber has the hump on the exhaust side of the chamber that helps get the smaller cc combustion chamber. I just got a set of 241s yesterday and the ramp in the intake port is also more squared looking that the others too.
Don"t forget what I told you guys about the swirl ramp!!! you can take about 75% out but not all,You will hit the water jacket
Ask me how I know that!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Fastone, I have a simple way to quelch that issue of going through the ramp into the jacket. I just went ahead and cut all the through the head on purpose to see how much room I had. Not to mention the cross section with the chop saw!!!! Destruction for education, there is nothing better.
Brandon
Brandon
Yea that was cool,but wasn"t it a 853 casting?I would love to do that to a 241 casting!!I"ve ported my 241 heads to 235 cc"s and 90 on the exhaust,only problem was swirlramp.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Yea that was cool,but wasn"t it a 853 casting?I would love to do that to a 241 casting!!I"ve ported my 241 heads to 235 cc"s and 90 on the exhaust,only problem was swirlramp. ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Updated sig.
Brandon
Brandon
Later
Brandon
Later
Brandon
Originally Posted by Bo White
Not to bump an old thread but was wondering what you meant about not bothering with the 98 head? I have done a set and they turned out the same as the other style heads and really the only dif' I see is the perimeter bolt pattern. You can get over 270cfm through a ported 215cc intake runner with a stock valve on the '98 or any year, that what I have been gettin'. The exhaust side is the same, 80cc with the stock valve flowing over 200cfm. Granted I do not open up intake runners like the rest but that is just the way I do my heads. You can get the port alot bigger and get about 20cfm more but does it really pay off when the stock intake is put back on? Just asking.
Brandon
I see that point. I understand what you were getting at now. The main reason the 241 is better out of the box flow wise is 1 the intake valve has a "back cut" made into it and 2 the area around the intake valve guide is slightly better on the intake side. The reason they flow roughly the same after porting is because you redo the port around the guide so the factory shapeing is for not and the older valves get the back cut done when you do the valve job at the machine shop. There are alot of 241s poping up here lately, I just had a set offered to me this morning and I bought a set for core work a couple of weeks ago. The only reason I keep all 3 styles of 5.7 LS1 heads is because most that talk to me what the same style head they send me, and I personally like doing it that way also.
Brandon
