spend $3000 for me?????????
Ok here we go the car in question is a 2000 ss camaro.
car weight #3636 with my fat ***
here are the mods :
ported oil pump
duble roller timing chain
918 springs
titaninum retaners
\welbro 255lph in tank
optome battery
Ls6 heads decked .10 with gm mls gasket ? (dont know compression ratio)??
231/237 cam
head studs
ls1 motor sports lid
slp lt heades (for sale want kooks)
slp y pipe
ls6 intake
ported tb
slp maff
28.8 lb inj
2 step
light weight carpet (ls1 speed)
t-stat
fan switch
12-bolt 4:11
dennys drive shaft
sphon tq arm
bmr control arms and panhard bar
up graded tranny M6 with kevlar blocker and viper shift fork
slp subframe connectors
wolf 6pt cage
asp underdrive pullies
amw oil catch can
harlen shift light
pro 5.0
lou short stick
no cats (but have them for emissions.)
magnaflow
full slick set up draglits and hooser qtp 11psi (hot)
have autotap
want efilive and ls1 edit (emissions coming to NY)
hade TNT F1 Kit at 150 shot did not like it too vilonet when it hit in
car is making 407. 383tq runs 11.8 with 1.78 60'
i want more power where do i go from here
i problely forgot some mods
here are the mods :
ported oil pump
918 springs
titaninum retaners
optome battery
231/237 cam
head studs
slp y pipe
ls6 intake
ported tb
slp maff
28.8 lb inj
2 step
t-stat
fan switch
12-bolt 4:11
dennys drive shaft
sphon tq arm
wolf 6pt cage
amw oil catch can
harlen shift light
pro 5.0
lou short stick
magnaflow
have autotap
You're making 407 with a 231/237 and LS6 heads? That seems a little low.
I'd say go FI. Put the money aside til you get some more and get a Procharger or a turbo setup.
That or get your heads ported by someone like TEA. That would REALLY help out(didn't see you mention if they were ported, just that they were decked).
1) adjustable shocks. you have the torque and the tire for a better 60' but it doesnt look like youre doing too well with traction.
2) dual stage or progressive controller for your old N20 setup to make the hit less violent(or with the controller, not violent at all)
3) electric water pump
4) lightweight drag racing wheels
5) fiberglass hood
6) lightweight K-member and A-arms
i dont know how much that all comes out to but those are some things that you dont have listed and i know the sponsors could easily get them for you.
5) fiberglass hood
No i am reaely turned off by nitrous i do not like the hit it is to explosive for me.
that is the trouble right now i do not know where to go from here have to be able to take car of all cobras and the the ls7 vet coming out. The is to much invested in the car to just sell it and but a new vet pluss i do not like vetts and will keep my f-body till i die. Wife clame i am cheating on her with the (Black Bitch) as she calls her. And to add i sold the kit becaus i did not want any part of it.
And yes you are right the heads ansd just stock not ported. but i can not see paying 1000 for 20hp at the most buy having thm ported.
TT-TECH Veteran
Yeah I would suggest having heads ported, but if you are thinking of FI then rething your head selection to maybe a set of 6.0L with the bigger combustion chambers etc.A dual stage setup on the nitrous wouls really help the hard hit you are talking about too. Also weight savings K-member and A-arms could shave a few ten's off. If you go FI just get ready there are a lot of other cost's around it like the fuel system just read a little in the fuel injection section and you wil see what I am talking about I will tell you that my FI set up is kinda violent also but it is a smooth hit but comes on very strong and keeps pulling. I try to explain it like a two stroke motorcycle like when the power band kicks in and it just takes off it is very simular. I hate to tell others what to do with their money when the goverment tells us what to do with so much of it already!LOL!
let me know if i am thinking right would you spend any money on porting heads that have been decked .10 it seames that the porting company has all the powere here if some thing happens all thy will say is we did not touch them first so you are **** out of luck give me 3000 for a new set of heads.
so what i am getting is spend money on weight or a procharger. that lends me to think what will my stock bottom end do on a FI set up should i get a 427 set up on the short end and build from there.????????
Just do the correct nitrous setup and be gold.
A progressive controller would work well and so would a 3 stage setup.
The nitrous will then feel more like a turbo then nitrous.
Its a real neat feel, make the car feel like its all motor power because you never feel a hit of any kind but your MPH climes like a ****.
