231/237 owners come in
Old 11-09-2004, 07:45 PM
five0killr's Avatar
Default 231/237 owners come in
i was just wondering where you guys made peak power(rpm) on the dyno..mine topped off at 6600..isnt that a bit low? and does 13.3 seem a bit low for a/f at peak power?
Old 11-09-2004, 09:18 PM
00sscam's Avatar
407hp/383/tq at 6200 max at 6800
Old 11-09-2004, 09:28 PM
five0killr's Avatar
hmm...do you remember what the hp diff was between 6600 and 6800?
Old 11-09-2004, 09:44 PM
WicketMike's Avatar
mine peaked around 6600, but never dropped off and took it up to 7000
Old 11-10-2004, 08:19 AM
c5jonny's Avatar
my car hits the rev limiter at 6400, power was still climbing.
Old 11-10-2004, 09:20 AM
LS1TECH Sponsor
Steve Burger's Avatar
Mine is flat as a board from 6200 - 7000. I shift at 6700.
Old 11-10-2004, 08:34 PM
Mike98WS6's Avatar
Mine made power up to 6,600 and stayed there to 7,000. I shift at 6,700 too.
Old 11-10-2004, 10:03 PM
Tranzor's Avatar
I have my limiter set at 6900, I shift around 6700. Makes power all the way up there...
Old 11-11-2004, 03:30 PM
LS1TECH Sponsor
foff667's Avatar
limiter was set at 6600, peak was made at 6300 but pretty much flatlined after that...a/f was 12.6 at peak tq and 12.8 for the rest of hte run.
Old 11-11-2004, 04:16 PM
Tweakd's Avatar
Mine made max hp is 6600rpm and stayed constant till 68/6900ishrpm then lost about 10hp per 100 rpm.
My max power was 421/385 w/ LS6 intake, PPLS6 style heads, LG Pro Longtubes w/high flow cats, corsa indy catback, vararam intake, stock everything else. I also was at 100% duty cycle on my 22.4#injectors from 4500-6900.
I put some hand ported LS1 heads in place of the PP heads, added volant air bridge, 28.8 LS6 injectors, so I will let you know what it makes with the replaced stuff.
