Question about a Comp Cam
Old 11-18-2004, 11:02 AM
RedDragon's Avatar
Default Comp Cams 114 224/224 568/568 ????
I need to know a little about this cam: Comp Cams 114 224/224 568/568.
Is this a good cam for a daily driven car?
I currently have this cam in my car, and am impressed with it, but need to know a little more about it. I have stage 2 ls1 heads, ls6 intake, 1.75 magnum roller rockers, and stud girdles.
What is the expected powerband on this cam?
Any information is greatly appreciated.
Paul
Old 11-18-2004, 12:37 PM
Rays C5's Avatar
Need more detail. As in valve events,duration at various lifts,etc.Those specs are simular to the famous Thunderracing "224" and if thats the case
a search with "224 cam" should net you a days worth of reading.
Old 11-18-2004, 12:41 PM
Unaffliated Racing's Avatar
Is this a red trans Am..with a cage..that you just recently purchased?
Old 11-18-2004, 01:19 PM
RedDragon's Avatar
Yes, it is. This car is a badass. I bought it from Jeff here on Ls1tech. Just wondering what I can safely have it pull to in the rpm range. I'm taking it to the track this weekend if weather permits, and don't want to screw it up. Everything seems to be working so well so far.
As for the daily driving, it is perfect. Just curious about the long term of things being daily driven with this set up.
Oh, and I have one of your strut tower braces that he gave me as well.
Paul
Old 11-18-2004, 01:44 PM
GTS346's Avatar
Thats a comp XE, good choice of cam there perfect for a daily driver.
My XE220 has a 113 LSA and peaks at 6,000rpm so I'd say yours would peak anywhere from 6,200-6,400 with a 114 LSA. Does it really start picking up at around 3,000rpm and by 4,000rpm it feels like it wants to fly?
Old 11-18-2004, 02:04 PM
RedDragon's Avatar
It does about what you said. The power feels like it doesn't want to stop when I shift around 5,500.
Paul
Old 11-18-2004, 03:12 PM
I am the one who built every part of that car.
feel free to give me a call 1-800-365-9145 ext. 558
Thanks,
Brian
Old 11-18-2004, 03:51 PM
bigdsz's Avatar
I think that is a custom Comp grind. Comp has a grind XR275HR 222/224 .566/.568 ona 112 lsa that has an RPM range supposedly up to 6800. XE, not XER lobe. It's probably comparable to the TR 224/224 .563/.563 114 lsa although I'm not sure if the ramp is quite as aggressive.
Old 11-18-2004, 04:02 PM
Yeah it's custom grind that I did. I shift that car at 6500. The last time I launched that car the two step wasn't active and launched at 6000 and pulled the wheels a good bit.
