MTI 2E or Patriot LS6 heads
Trying to decide whether to get the MTI stage 2E or the Patriot LS6 style head. Looks like both will add about the same amount of power. I tried a search on the MTI 2E heads with no luck. Any insight is appreciated. I'll be matching the heads to an FM-11 cam.
thanks.
thanks.
Search "issue" is currently being worked on by the admin.
Here's a couple threads on the MTI stuff:
https://ls1tech.com/forums/generation-iii-internal-engine/232843-need-input-mti-2e-stealth-combo.html
https://ls1tech.com/forums/generation-iii-internal-engine/218680-mti-5-3-stg-iie-g1-cam-c5-6spd.html
https://ls1tech.com/forums/generation-iii-internal-engine/212475-mti-power.html
BTW, I'm a happy (10 second) MTI customer
