Lunati 230/237 weird cam !
Old 12-17-2004, 07:02 PM
FiveSevenEagle's Avatar
Default Lunati 230/237 weird cam !
since my mind is up side down for 4 months now .. wondering which cam to choose on my stock ls1 heads .. headers ls6 intake manifolds and 80 TB and a cutouts, Automatic tranny.. the final candidates are G1 (MTI) 228 232 575/588 113 , TR224/224 563/563 114 , Lunati 230/237 544/543 114
the G1 cam is out of the competition it is between the TR224 and the Lunati
am worried about the Lunati because of the lift but close friend tried it and it was Very Very nice , the Tr224 has a great reputation and great numbers ..
all UR CHOICE GUYZ .. choose one and i dont care cause i started to feel sick
ill see the best vote and ill go for it ...
waiting ....
Old 12-18-2004, 08:05 AM
FRCBobby's Avatar
I think there is a guy on kyhorsepower.com running the Lunati cam you are talking about. It is very stout to say the least, very driveable and easy on valvesprings. You can go on there and search for his name and maybe send hum a message, his name is Jonezy.
Old 12-18-2004, 10:18 AM
JS
JS's Avatar
TR cams rock
Old 12-18-2004, 11:47 AM
FRCBobby's Avatar
Well, the TR cam is good also, also know a guy with the TR224 and ported heads putting down 405 at the wheels NA, and 530 on the spray.
Old 12-18-2004, 11:52 AM
redrocketls1's Avatar
may i ask why u ruled the other cam out? i was thinking this was in my top 3
Old 12-18-2004, 12:20 PM
tomaSS's Avatar
Don't rule out the FMS cams. Do a search, there is a ton of info on these cams. They produce great numbers and are great for drivability. Just a thought.
Old 12-18-2004, 07:34 PM
u mean the G1 ? many reasons .. first lemme say this cam has a great out come but bad QM compared to other cams like the 2 ive chose .. HIGH lift which has disadvants ... other i have 2 deal with MTI while am Over Sea which is not easy ...
Old 12-18-2004, 07:58 PM
Mr. Bungle's Avatar
I had a slightly different cam i had the 224/224 .581 112 lsa and i got 408rwhp and 390rwtq with PP ls6 style heads. It idled great and made great low end power. I have a blower now so i have a different set up but for n/a it's great. Especially for a daily driver.
Old 12-18-2004, 07:59 PM
11 Bravo's Avatar
I have this cam. I was going to run it with stock heads but decided to just concentrate on my stroker. I have heard of only a couple who have run it, but the results have been great. Someone with FFHP stage 1 heads was running mid 11's I believe. I got it because the lower lift would work good with stock valves, and it would not put much stress on the springs. Most people on here only like cams with major lift, but cams like this one, the ASA, ect have had great results. And you will have peice of mind that you won't break a spring out in the middle of nowhere on a road trip.
Old 12-18-2004, 08:06 PM
thanx man .. i read the thread there he was talking about the Lunati 230 237 cam .. but sadly i coudnt get his E mail or Private message .. i did the registeration but an Error message is showing to me telling me that u can send private message .. whatever if u can get me his E mail .. ill be appreciatin that .
thanx again
Old 12-18-2004, 08:12 PM
guys am talking about stock heads STOCK ... u need more duration to get benefit in the stock heads not lift .
i need u to force me .. am about to click the order button .. haaaaaa !!!!
Old 12-18-2004, 08:17 PM
ok what pushrods , springs , retainers to choose with ?
am about to order it am that --__ close to order it
Old 12-19-2004, 02:36 AM
Full-Force's Avatar
go ahead and order me one too, i will send you my mailing address
Old 12-19-2004, 05:14 AM
Restricted User
CAT3's Avatar
I would go with the Lunati personally. Of course I have the TSP (Lunati ground) 231/237 and with shitty *** 853 castings runs good as hell! That belief about lift and duration with stock is true......to a point. Yes you can overcam true enough, but its also easy to have a duration exceeding the runner volume etc etc etc....and some ppl believe that you can use more lift & duration to cram more in, to assist in the blending or whatever. All I know is, I had the TR224, very nice cam indeed. I swapped out to the TSP 231/237 and I wouldnt go back to any thing smaller.
Where are you at overseas?
Old 12-19-2004, 11:13 AM
FRCBobby's Avatar
thanx again
I will get his email address for you. He will answer every question you have about that cam, well at least he answered mine.
Old 12-19-2004, 12:09 PM
cyphur's Avatar
If you're so bent on ordering a cam, go ahead and order me an F13 112 +2, I'll send you my mailing address as well
I'd look into the FMS cams as well, great power with good drivability. But if you're stuck between these two cams, I'd go with the Lunati.
Quick Reply: Lunati 230/237 weird cam !
