Here's a clip of the TSP Torquer
Old 12-17-2004, 10:43 PM
Silverhawk_02TA's Avatar
Default Here's a clip of the TSP Torquer
Just finished the install yesterday. The clip is on LS1Sounds.com under the true duals page, the first clip at the top. Let me know what you guys think!
Old 12-17-2004, 10:53 PM
Raise's Avatar
very nice man....i was lookin at goin with the torquer, but i got the h/c package deal with MTI. but dave said he might be able to custom grind something around those specs for me. anyway, didnt mean to trail off there. sounds really good buddy....get a dyno and let us see that torque curve. u have stock heads??
Old 12-17-2004, 11:01 PM
Yep, stock heads. Gonna try to get a tune here soon, and get it to the dyno not long after that. You gouys will be the first to know!
Old 12-17-2004, 11:08 PM
tomaSS's Avatar
Nice! Let us know your numbers when you get it tuned.
Old 12-17-2004, 11:19 PM
pdd
pdd's Avatar
that thing sounds sweeeeeet!!!
Old 12-18-2004, 01:08 AM
MachoCamacho's Avatar
sweet, but why does everybody videotape their fbody's at night , i've especially noticed black ones...
Old 12-18-2004, 01:47 AM
5POINT7's Avatar
Nice, sounds sooooo much diff from in front of the car to behind it! Love the lope. How's the SOTP feel of the 233/233?
Old 12-18-2004, 12:29 PM
Feels really strong. It was kinda hard to tell cause the roads were wet, and getting on it at all pretty much broke the tires loose, even from a 20 or 30 mph roll. Night and day difference before and after!
Old 12-18-2004, 03:22 PM
2000Hawk's Avatar
i was deciding on ordering the Torquer also but i am wondering i will be installing SLP LT, 3in. X-Pipe and, Magnaflow 4x9's will my car sound alittle quieter than his or will it be roughly the same cause i noticed he has the TSP true duals.
Old 12-18-2004, 05:18 PM
Checkmate's Avatar
I would say the tsp duals would be louder.
The clip sounds awesome.
Old 12-19-2004, 09:38 AM
Bill Bowling's Avatar
Talking
Just received my torquer cam. Still need a few more parts. I can not wait to get it installed.
bill
Old 12-19-2004, 12:37 PM
1BadMoFo's Avatar
sounds friggin perfect man!
Old 12-19-2004, 01:35 PM
sleeperstyle's Avatar
very nice sound. im also concidering this cam for stock heads setup... definetly post dyno#'s or track times..
Old 12-19-2004, 01:40 PM
JoeT/A's Avatar
We just put this cam in a buddies car. Made 391HP and 370TQ. With over 300TQ from 2800 to 6800. This cam is a hoss down low, feels great on the street.
Old 12-19-2004, 07:55 PM
Z-286speed's Avatar
After you get that tuned, will you lose most of that lope in the cam?
Sounds really nice!
Old 12-19-2004, 08:29 PM
Sounds really nice!
No. The hot-idle is set at about 800 RPM right now. With a tune I MIGHT even be able to lower it a tad. Lower idle = more lope.
Had a local guy from the board come by earlier to check out the cam and exhaust, and we went for a little ride. It was the first time I'd really gotten on it since the install, and all I can say is "". I launched her real easy from a stop, and then dropped the hammer. As soon as it hit 2k RPM the tires ripped loose and the back end kicked out. The tires didn't start grabbing again until mid-way through 3rd gear. It was as close to a religious experience as I've ever had.
To anyone who has this cam on the way, or is thinking about getting one, you will NOT be disappointed!
Old 12-19-2004, 08:32 PM
SmokingWS6's Avatar
Sweet, cam sounds mean
Old 12-19-2004, 09:56 PM
Z-286speed's Avatar
What all did you replace with the cam? I need to know if i need that oil pump and chain? Thanks
Old 12-19-2004, 10:06 PM
nick3205's Avatar
Sounds nice. Sweet cam
Old 12-19-2004, 10:42 PM
It's not necessary to replace the oil pump and timing chain, but it's not a bad idea to upgrade while you are in there. I didn't, since I have low miles and the oil pump in the 01 and up f-bodies was better than in the 98-00. If I wasn't working within a budget I probably would have swapped them out, though. You definitely need to beef up the valvetrain. You could run a quality single spring with no problems, since the lift is under .600. I decided to go with the PRC dual spring kit from TSP, which came with the springs, seats, valve stem seals, titanium retainers, and hardened pushrods.
