Header & Cam Install
i'll most likely be ordering the TSP 233/239 with the Precision Racing Components Kit. and i'll be installing my SLP Longtubes w/ a Custom True Dual set-up (3in X-Pipe with Magnaflow 4x9'x) basically i want you guys to see things i am goin to order and see if i need anything else.
-LS1 EGR Manifold Plug
-MSD 8.5mm Plug Wires
-NGK Spark Plugs
-GM Steel Header Gaskets
-Crane Cams Valve Spring Compressor
-JPR Cam Install Tool
-Thunder Racing Basic Cam Swap Gasket Kit
-ARP Cam Bolt Kit
-ARP Cam Retainer Plate Bolt
Basically this is all i can remember if theres anything i am missing that you guys feel will make it easier or things that i listed i don't need please post. Thanks
-NGK Spark Plugs
-ARP Cam Bolt Kit
If your LT's have hook ups for AIR and EGR and you plan on removing them, you'll want some black off plates. Also the stock GM steel gaskets for the manifolds are well made and can be reused, but that isnt a bid deal. Print out the install guide from LS1howto and you should be set. Gonna be a sweet set up.....
Originally Posted by jrp
!wires
!arp cam and cam plate bolts
!JPR tool
add Pushrods, timing chain, and oil pump (optional but i'd just as well). keep the stock wires and cam bolts and make your own JPR tool with rods from home depot/lowes
!JPR tool
thanks guys i'll make sure to get all this down. so those Dowels you guys are talking about from lowes they are just rods like the JPR's all i would have to do is bend them so i can pull them out right?
i was wondering can i re-use my factory header bolts. well i am deleting my EGR since i am using LT's from an '02 SS, thats why i am getting the LS1 Manifold Plug.
i was going to get the Torquer until seeing the 233/239 and TSP says it makes nice torque and great top end power. and the headers and exhauast system have been in my garage waiting for the installation.
