Anyone Tried a TSP 235/240?
Old 01-12-2005, 09:25 PM
Cal
Cal's Avatar
Default Anyone Tried a TSP 235/240?
I just orderded one. Full specs are 235/240 .602/.598 112. I did a search on the enitre forum and came up blank. I know this isn't a common cam, but I thought someone else might have one. It's supposed to have close to XER lobes, and I'm installing it with a fresh set of Comp 918's. Any comments? Not sure what to expect.
Old 01-12-2005, 09:29 PM
Beast96Z's Avatar
I'd like to see the advetised duration. The cam has 2 diffrent lobes for intake and exaust, so it would be interesting to see which lobes they used. Should be a great performer. It should perform like a G5X-3 since the numbers are similar, but again, since the lobes are diffrent, performance may vary.
Old 01-13-2005, 03:25 PM
Cal
Cal's Avatar
Beast, yeah it's close enough to the G5X-3, maybe I should check some posts for that cam.
Old 01-13-2005, 03:29 PM
NO5.0's Avatar
whats the specs on a G5X-3, would it work well with the AFR 205s?
Old 01-13-2005, 03:30 PM
pdd
pdd's Avatar
there secret
Old 01-13-2005, 03:41 PM
Ed Curtis's Avatar
Originally Posted by pdd
there secret
The specs are...
Well it's
I mean they are
Duration at...
Exhaust specs...
Advertised duration...
nevermind...
Ed
Old 01-13-2005, 03:54 PM
greekss's Avatar
r u nuts.... I wouldnt even think about running that cam with the 918's but hey whatever
Old 01-13-2005, 04:10 PM
NO5.0's Avatar
whats the big secret?
Old 01-13-2005, 05:15 PM
Beast96Z's Avatar
Nothing real secret about it. They've been posted many times before, but they keep deleting the threads when they are posted. There comp XE-R lobes. One step up from the G5X-2. Don't know why alot of people make a big deal out it.
Old 01-13-2005, 05:34 PM
cyphur's Avatar
(in my best robin william's voice)
shhhh!!!!! there's a gay mafia!!!! shhh!!!!!!
they're just real protective of their shiot. even tho anyone who has bought their cam could throw it on a cam doctor and get the specs
Old 01-13-2005, 05:47 PM
Cal
Cal's Avatar
Well I think it's OK to talk about the G5X-2 specs now since it isn't the latest thing:
232/240 .595/.609 112 XER Lobes
Old 01-13-2005, 05:49 PM
Cal
Cal's Avatar
I'm actually using this cam BECAUSE of the 918 springs; the lift is in range for them. If I liked duals, I would have went with the TSP Magic Stick.
Old 01-13-2005, 05:57 PM
tomaSS's Avatar
Its just that most people would go with dual springs with that big of a lift.
Old 01-13-2005, 06:00 PM
luv2spd's Avatar
Why don't you like duals?
Old 01-13-2005, 06:14 PM
Cal
Cal's Avatar
I don't like duals because they are heavy. I think springs hold up better if they are not moving so much weight, and part of the weight that they move is their own weight. And look how much smaller and lighter the retainers are on 918's. I run stock valve sizes for the same reason. That's just MHO. Weird, huh? But I'm not a drag racer, so I have different priorities. In Land Speed racing, I may need to hold peak rpm for 30 seconds to a minute, so I have to think about durability.
Old 01-13-2005, 06:31 PM
NO5.0's Avatar
About the specs on the G5X-3 I was wondering because of the decision on which cam to go with with the AFRs? If it was posted before I didnt know I am new to this forum. Is there any post that shows power output or graph for torque range? Thanks
Old 01-13-2005, 06:37 PM
Cal
Cal's Avatar
Here's one, LS6 heads though:
https://ls1tech.com/forums/showthrea...ighlight=G5X-3
Old 01-13-2005, 06:55 PM
NO5.0's Avatar
CAL, Thanks. Would I have to flycut the pistons with an AFR 205 62cc and the g5x-3? That sounds like a good pwr maker and still streetable, sweet. I just want to make some serious power, close to 500rwhp as possible, and put an a$$kickin on my buddies 03 cobra!
Old 01-13-2005, 07:04 PM
LS1_PNYTAMR's Avatar
i been on tsp's website a lot, never seen the tsp 235/240. intresting looks like its b/t the 233/239 and 237/242... prolly not to much different from either..
Old 01-14-2005, 02:55 AM
greekss's Avatar
hmm i thought the max range for the 918s was 600 lift ?
