is this pushrod bent? *pic*
Old 01-15-2005, 02:13 PM
That's what she said...
TheBlurLS1's Avatar
Talking is this pushrod bent? *pic*
tell me what you guys think??
from the #7 cylinder intake valve
it seems to have extended the hole that the pushrod drops into in the head toward about 7 oclock by about 1/4". will it be safe to put a new pushrod in this hole? i'm guessing the lifter and the rocker will hold it in place and this hole being a little "extended".
i guess this explains my ticking noise
Old 01-15-2005, 02:18 PM
dug
dug's Avatar
looks fine to me.
What the hell did you do to cause that? The dreaded 2-3 misshift into 1st? Ive been lucky. Ive made some of those misshifts but only when driving real slow in traffic. Accidently shifting into 1st at 20mph. oops
Old 01-15-2005, 02:19 PM
Mike98WS6's Avatar
It looks like a shifter to me.
Old 01-15-2005, 02:20 PM
TheBlurLS1's Avatar
i was thinking allen wrench
sucks so bad i cant stop laughing
but what about my questions?? they are serious lol, and where can i order some new hardened ones today? i've never researched any internal engine stuff that much, because i diddnt plan on buying anything very soon, guess i am now!
Old 01-15-2005, 02:23 PM
goober35's Avatar
That is nothing. I had a buddy miss a shift and his push rod looked like a S
Old 01-15-2005, 02:36 PM
Krab's Avatar
Beh, I wouldn't worry about that too much. Just buy some new pushrods, swap them out (or just the bent one if they're the same kind) and move on. I had one pushrod look something like that (not as bad though) when I did my cam swap. It also nicked the hole in the head a little too, but I just put in the new pushrods, closed her up and she's been running fine since.
Old 01-15-2005, 02:46 PM
TheBlurLS1's Avatar
thanks for the info guys!!
what are some good hardened pushrods? i need to order these today and dont really have time to do research like i normally would. anybody have any suggestions? TSP has manleys for 110$
Old 01-15-2005, 03:03 PM
black_z's Avatar
TSP, Thunder, Speed Inc, HPE, a hardened pushrod is a hardened pushrod as far as im concerned. Go with the cheapest ones.
Old 01-15-2005, 03:08 PM
dug
dug's Avatar
If youre not running a cam, hardened pushrods are kinda pointless. Cuz if you had hardened pushrods when you missed the shift you would have bent the valve instead. Causing a lot more damage.
Old 01-15-2005, 03:30 PM
Cal
Cal's Avatar
Maybe you can bend it back . . . just put your car in reverse and floor it
Old 01-15-2005, 03:57 PM
Bill00Formula's Avatar
When my timing chain broke, a couple broke in two places
Old 01-15-2005, 04:27 PM
Another_User's Avatar
I agree. Put it in a vice, and latch on to one of the tips with some vice-grips, and yank the heck out of it. It'll be fine.
Old 01-15-2005, 05:07 PM
LSX Mechanic
Damian's Avatar
Do not run hardened pushrods in a stock motor. If you ever do another misshift you will seriously **** some **** up.
Nice work BTW. I've bent many a pushrods in my day....
Old 01-15-2005, 05:48 PM
liqour enthusiest
88monte's Avatar
that looks fine, just throw it back in and have fun
Old 01-15-2005, 06:11 PM
smokeum99ta's Avatar
my dick is staighter than that and I have one hell of a hook.
my friend bends his [push rod for you preverts] about every 2 weeks and keeps using my old ones to fix it. i swear his rev limiter doesnt work. ive seen him rev it over 7000 rpms and his bottom end is stock . i guess he'll never learn till one of those rods come flying out of the block
Old 01-15-2005, 06:22 PM
TheBlurLS1's Avatar
can i put some dual valvesprings, titanium retainers etc, in right now and run the hardened pushrods and dual valvesprings with a stock cam? i was going to put in duals when i did my cam (in the future), but would it be ok now?
would it be ok to put in all the stuff as if i was putting in a bigger cam, and run with the stock cam for now?
what exactly is it that causes the pushrods to bend? is it really bad valve float or what? i did the dreaded 3rd to 2nd shift instead of 4th i always forget to turn my hand toward the inside when i'm trying to hit 4th gear.
sorry for all my questions, but thanks for reading my posts!
Old 01-15-2005, 06:30 PM
That is the grossest thing I have ever read on LS1tech.
Old 01-15-2005, 06:34 PM
slow's Avatar
ditto.....
Ryan
Old 01-15-2005, 06:35 PM
1BADAIR's Avatar
It bent due to excessive RPM causeing valve float. If you upgrade the pushrods the next time it happens you will break a valve. I would install upgraded springs at the same time then you won't have to worry about valve float
Old 01-15-2005, 08:24 PM
cyphur's Avatar
damn dude.....
just get some stock PR's from someone that did a cam swap or call a sponser....they may have some layin around from a swap.
Quick Reply: is this pushrod bent? *pic*
