What springs for this camshaft?
Old 02-05-2005, 12:36 AM
The Guy in MY 99TA's Avatar
Default What springs for this camshaft?
Its a FMS 230/236 I'm not sure the rest of the specs. I bought it used w/ about 1000 miles on it from a friend who went to a much larger fms cam. I was wondering if the 918's would be sufficent for this?
I'm not familiar enough with the FMS cams to know which one it is FM11,FM12 or whatever.
Josh S.
Old 02-05-2005, 12:41 AM
Blue02Ws6's Avatar
I doubt it is over .600 lift so 918's should be fine.
Old 02-05-2005, 01:02 AM
LS1_PNYTAMR's Avatar
f11 is 228/230 and f12 is 230/230.. f13 is 230/232 and f14 is 232/234...
a f9 is 232/236 which sounds like somethin similar to urs.. all the fms cams are in or around .600 lift, 918's will prolly do fine but id suggest some duals for added saftey, up to you though.
Old 02-05-2005, 03:24 AM
tomaSS's Avatar
I have the F12 (230/230 .595"/.595") and FMS recommended dual springs. Do you know the lift #'s on your cam?
Old 02-05-2005, 06:27 AM
I guess I need to call Allan next week and ask him.... I was told the numbers on the camshaft when the engine was built and I just can't remember. Its close to 600 i believe.
Josh S.
Old 02-05-2005, 07:50 AM
jamnut's Avatar
I'm running Patriot Gold duals with my F11, not because 918's wouldn't handle the cam, but because I figured that I would get more miles out of a set of springs before I changed them. Also I still can't get used to the idea of a single spring, I guess I'm old school, but I like the safety factor of having a double spring, less chance of a broken spring causing PtoV contact. Also by the time you price out a set of 918's with titanium retainers & seals, the Patriots are about the same price for the whole kit.
Old 02-05-2005, 11:19 AM
jbuckweiser's Avatar
Talking
Josh S.
I've been in contact w/FMS and their camkit comes with dual's just like
TomaSS said.
Old 02-05-2005, 04:43 PM
01_SuperSlow's Avatar
I was recommended some PRC duals for my FMS cam.
Old 02-05-2005, 06:52 PM
Turo's Avatar
Same here. I took their advicxe and I am happy with them so far.
Old 02-06-2005, 04:44 PM
smask04C5's Avatar
crane duals nice kit, quiet too
