Balancing a crank?
Old 02-13-2005, 05:46 PM
HAMRHEAD's Avatar
Default Balancing a crank?
What is involved in balancing a Crank? I tried searching but it is to general. How do you do it?
Old 02-13-2005, 06:05 PM
Demon SS's Avatar
you take it to a machine shop that has a crank balancer.
the crank balancer spins the crank and tells you where the weight need to be added or removed.
Old 02-13-2005, 06:30 PM
HAMRHEAD's Avatar
Forgive me for being stupid but if a crank is bought balanced then I assume it was already done and is ready to install?
Old 02-13-2005, 06:32 PM
smask04C5's Avatar
Correct,crank will be but rest of rotating assembly, if not part of purchase should be checked
Old 02-13-2005, 06:48 PM
Grimes's Avatar
You have to bring your rotating assembly...pistons/rods/crank; sometimes dampner and flywheel to an engine shop to get it all balanced properly.
Old 02-14-2005, 09:15 AM
HAMRHEAD's Avatar
So there is almost no way you can put your own engine together unless you have the machine to balance this stuff? Do you have to have it all balanced together or can you do seperate pieces? Like if all you already got the crank balanced and just need the rest done?
Old 02-14-2005, 05:41 PM
Lesrace82's Avatar
rods, pistons, rings, bearings, and sometimes balancer the flywheel/flexplate should be balanced together
Old 02-14-2005, 07:04 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
Don't try it. Hire an engine builder.
Old 02-15-2005, 09:35 AM
GuitsBoy's Avatar
Im sure its always the safest bet to hire someone who has done this hundreds of times before. But still, what harm would it be to fill us in on the black art of engine balancing. What tools are used? Where is material taken off? Is that material grinded off or drilled out?Ive heard that a normal balance job costc $150 - $200. On one hand, why not pay someone since its so cheap. On the other hand, how much work could it possibly be if shops only charge $150.
Old 02-15-2005, 09:45 AM
V8er's Avatar
This is also what I have been told. I wonder how advantageous the balancing is for a motor that will see 7000rpm many times?
Old 02-15-2005, 10:30 AM
HAMRHEAD's Avatar
I was just looking into it since I love working on my engine and challenging myself with new stuff. It costs so damn much to have it all installed in a block.
Old 02-15-2005, 05:48 PM
Lesrace82's Avatar
You can still build it yourself, just have an engine builder balance it for you.
