cam install? timing?
when installing the cam i know the chain is moved around a bit, but is there any major problem when all things arent lined up right upon reassembly? i have seen that it is very important to line up everything but how important?
You MUST Phase the cam properly
You can be several dgrees off for your camshaft timing without any adverse effects. Actually, many advance cam timing a few degrees to increase low end torque and improve idle. Others retard the cam a few dgrees to increase top end horsepower.
If you dont line up the dots on the gears, and you are off by several teeth, SEVERE damage can result. Pistons can come into contact with the valves if the valves are opened at the wrong time. You will have to deal with bent valves or worse!
Originally Posted by jrp
wow, just......wow
put the tools down and step away from the vehicle.
LOL....what JRP said.
If you MUST do it.....check, recheck, check again, then quadruple check that the dots are lined up before you finish everything up. One tooth off *could* cause severe engine damage. Buy a Helms manual too and follow it to the 'T'.
i don't see why people think that it is so hard to line the dots up... it took all of 1 minute to line the dots up...now getting the cam sprocket on the cam was another thing...that took a little bit (5-10 min) cause the chain had 0 slack in it...so i had to pull super hard to get it to line up on the dowel and the bolt holes...this was also the first time i had done any mech. work so that might be why it took a little longer too...
so it seems like there are two opinions, one it seems like some think that lining up the dots is diffucult and on the other hand its not" don't see why people think that it is so hard to line the dots up... it took all of 1 minute to line the dots up" kind of hard to decide what to do.
so it seems that i just have to take my time and check as many times to make sure its lined up. anybody know of a way to check if they are lined up right or just wait till it blows...............!!!!!
let me recorrect myself...it was easy but i'm sure it was easier for me...cam was already installed i just put in a new timing chain...i turned the engine over till the dots lined up...then i installed the crank sprocket to where the dot was up the i installed the cam sprocket to where the dot was down and the dowel fit in...then i tightened it up...the dots lined up and reassembled everything...should i have spun the crank some to see if it stayed lined up...i don't see how i could have messed this part up
Originally Posted by ls1_cam
yeah i got that, but just wondering if any body had any tips on how to check is all. Sorry if i seem stupid but dont want to damage anything.
just pay a shop too do it, you dont come across as very mechically inclined. better to pay someone so its done right then to **** it up yourself.
He prolly really oughta' find a bud whose done it once or twice to give him a hand.... but hey everyone's gotta do their first one sometime. Only way to learn. If he ****** something up... he'll have learned a very valuable lesson.
Haynes manual + proper tools + common sense = successful mod install(most of the time ).
Key words: Common Sense.
Good luck bud!
SN95 Director
Originally Posted by LowETz
Damn JRP..... yer hard
Good luck bud!
Good luck bud!
im not trying to be hard but the consequences of ******* up are huge. he just doesnt come across as compitent enough to do it alone. i'd at least get some help from someone local who's got the experience and can help him out.
Thanks for the tips yeah i have someone whos done it actually 4 times to his car but just trying to get a few pointers from the pros. sorry if i came across as an idiot but i have done some mods to my car just nt a cam.
