Intake Manifold Flow Test
Old 03-22-2005, 11:03 AM
jrp
SN95 Director
jrp's Avatar
Default Intake Manifold Flow Test Data
Steves words verbatim
I had some time yesterday to flow test the manifolds on your Patriot head. I flow tested using cylinder 5 runner as before. The Edelbrock is a dual plane manifold. On that manifold I first flow tested cylinder 5 runner which pulls from the high side of the plenum, then turned the manifold around and flow tested cylinder 4 runner which pulls from the low side of the plenum chamber. The low side generally flows better on dual planes because the runner has a straighter shot from the plenum.
The sheet metal manifold has really short runners. The actual runner centerline length is 3.75" down the centerline. This results in a plenum to valve back length of only 9.25". This would be too short a length to give adequate pulse tuning within the rpm range of a normally aspirated engine of this type. Work good at nine grand but that's outside the range of most engines. In any case, this manifold is going on a twin turbo engine. Should work fine under boost.
The Weiand manifold keeps up the the Fast up to .250" lift. Past that point the Fast takes off. I don't think this is due to the runner shape. I think this is a function of throttle bore size. Same holds true for the Stock LS6 manifold which has the smallest opening of those tested.
Sheet metal 91.5 mm throttle bore opening
Fast 90.2 mm
Weiand 78 mm
LS6 75.5 mm
If one were able to rework the LS6 manifold for a larger throttle bore, I'm sure the flow numbers would improve substantially. This manifold was bone stock. Both the Fast and Weiand were cleaned up internally and port matched.
The Edelbrock, as I mentioned above, is a dual plane manifold. This again was bone stock. The runners are smaller in cross section than on any of the other manifolds tested. Porting this manifold would help but it is difficult getting inside to rework a dual plane. I cut them open to rework then weld them back up. Too expensive to do unless it is for some sort of restricted racing class. I would like to flow test a GM or new Edelbrock single plane to see how those flow. In any case, the low side runner on the Edelbrock flowed quite well considering it's size.
Steve
i've said it once, and i'll say it again, steve is the man
i can post up each individual flow sheet if anybody wants them.
Old 03-22-2005, 12:15 PM
DanZ28's Avatar
Wow, thanks for the great info!
So if you could slap on a 90mm TB on an LS6 intake and bore open up the inlet, you would see similar results as the FAST intake?
Dan
Old 03-22-2005, 12:58 PM
TrendSetter's Avatar
any more info/pics on the sheetmetal that was used in this test?
Old 03-22-2005, 01:00 PM
jrp
SN95 Director
jrp's Avatar
its the same style as the nasty nate sheetmetal intake.
Old 03-22-2005, 01:06 PM
777's Avatar
didn't realize the ls6 flowed so well...i guess those numbers are even slightly skewed because
where as the ls6 was bone stock...
Old 03-22-2005, 01:10 PM
Bo White's Avatar
You can send the Edelbrock off to extrudehone.com and the Weiand as well for porting. The plastic pieces do not fair to well under the putty pressure.
Old 03-22-2005, 01:18 PM
ONEBADWS6's Avatar
Good Job once again. I got 260cfm out of a LS6 and 285 out of a ported Fast 90
Old 03-22-2005, 01:26 PM
DAPSUPRSLO's Avatar
Excellent post.
Old 03-22-2005, 01:36 PM
v8maro's Avatar
Nice, let's get an ls7 on there and see what it does.
Old 03-22-2005, 01:39 PM
DAPSUPRSLO's Avatar
Since this manifold will not bolt up to 15 degree heads I don't think you will see it in this kind of comparison.
Old 03-22-2005, 01:50 PM
gomer's Avatar
Great info! I'd like to see a 90mm LS2 intake done also.
Old 03-22-2005, 02:27 PM
Originally Posted by 777
didn't realize the ls6 flowed so well...i guess those numbers are even slightly skewed because where as the ls6 was bone stock...
ive 'ported' a weiand before and theres really very little that you can get to through their little access door in the bottom of the manifold. cleaning it up helps, but not nearly as much as one might guess.
Old 03-22-2005, 02:32 PM
427 LS1's Avatar
The sheet metal intake is a spectrum 5 racing piece. It is similar to the Nasty Perf. manifold. The sheetmetal, Weiand and FAST 90 are mine, the sheetmetal is going on the car for now, we'll see how it works out. Steve is a great guy and I appreciate all of his efforts, I'de like Steve to flow an LS2 and a single plane as well, which I have access to...Dave
Old 03-22-2005, 02:37 PM
JS
JS's Avatar
Lsx---->nuff Said
Old 03-22-2005, 02:50 PM
jrp
SN95 Director
jrp's Avatar
i forgot who steve said he got the manifolds from.
Old 03-27-2005, 01:28 PM
jrp
SN95 Director
jrp's Avatar
FAST 90 vs LS2 vs LS6
Wenzler four barrel single plane manifold
Old 03-27-2005, 02:38 PM
HumpinSS's Avatar
Was that a stock or ported fast intake?
Old 03-27-2005, 02:50 PM
JZ'sTA's Avatar
Nice results.
Thanks for the testing.
Old 03-27-2005, 05:11 PM
69firebird's Avatar
this is good info, so basically the edelbrock is the best flowing, its just getting those to fit under a stock hood is kinda challenging
Old 03-27-2005, 05:24 PM
pdd
pdd's Avatar
fast 90
Quick Reply: Intake Manifold Flow Test
