My new custom Ed Curtis Cam Specs...they're not small!
Old 03-30-2005, 06:18 PM
verbs's Avatar
Default My new custom Ed Curtis Cam Specs...they're not small!
236/244 .631/.631 113 LSA 111 ICL
Powerband from 3500-7000rpms There's a lot more going on with this cam than just the cam specs you see. Shift point is 7400rpms
Supposed to make a lot more power than the coveted G5X3. We'll see.
The cam is setup for maximum power on pump gas both on and off the bottle, i.e. no more than a 150-175 shot.
Will keep everyone updated. With the addition of this cam and my new additions including a LSX 90/90 setup, EWP, and better headers, I'd love to be at 480+rwhp N/A through a 12 bolt and 60lb 18x10.5 wheels/tires, NO dyno tricks, full exhaust, 28 degrees of timing, and 10.9:1 compression.......and of course some very low 10 second track times on bottle
Old 03-30-2005, 06:20 PM
99'Formula's Avatar
Thats going to be sick. Props man, let us know what happens
Old 03-30-2005, 06:23 PM
Viper's Avatar
Nice! Changing springs or rockers and lifters?
Old 03-30-2005, 06:24 PM
verbs's Avatar
Nope. Springs are already 921s with only a couple thousand miles on em if that, rockers will stay stock, and lifters are already Comp R lifters
Old 03-30-2005, 06:25 PM
66deuce's Avatar
care to share any more specs,if you have them?(i know what your going to say,but i had to ask,lol.)i was going to have Ed grind me one but i ran out of money when my DD broke down and had to fix it.
Old 03-30-2005, 06:31 PM
verbs's Avatar
I'll check with Ed first, but I think the answer will be no, and I don't blame him. The only other specs I have are lobe lift, and valve timing with respect to intake and exhaust open and close. I have nothing on the various cam duration specs at various tappet lifts.
Old 03-30-2005, 06:51 PM
MUSTANGEATER's Avatar
Sounds like a great combo. Is it a straight 1.7 rocker arm ratio? Good luck getting it all together.
Floyd.
Old 03-30-2005, 07:17 PM
tonyb's Avatar
That sound like one bad *** cam Ed had ground for you.You should put down some good #s.****,my tiny 220/224 EDC cam put down the #s in my sig before my CF DS,Exedy twin disc,EWP and ORPs.Ed is the MAN.
Anthony
Old 03-30-2005, 07:29 PM
goober35's Avatar
7400 shift point. That is just free power up there if the motor will hold together.
Old 03-30-2005, 07:32 PM
Louis's Avatar
Its bigger than the X3, so It better make more power
Old 03-30-2005, 07:44 PM
verbs's Avatar
Floyd.
Yep, 1.7 ratio.
SPANKY LS1's Avatar
Are you gonna dyno with the cam being the only change, or are you changing the intake, TB, cam, and headers all at once? I'd like to see how much the cam actually helps.
Shawn
Old 03-30-2005, 07:46 PM
verbs's Avatar
true dat! But not really bigger than the X4 (sans lift), so we'll see how this compares to the gains going from an X3 to an X4
Old 03-30-2005, 07:48 PM
verbs's Avatar
Shawn
I will be doing a dyno with the headers, EWP, and LSX 90/90 combo with the G5X3 for a baseline, and will swap to Ed's cam and redyno.
So yes, there will be a direct cam comparo.
Louis's Avatar
well in that case, its not going to make much more power than the X3.
same post time
Old 03-30-2005, 07:51 PM
verbs's Avatar
I really don't think it's fair to expect an off the shelf cam designed with stock heads in mind to make the same #s as a cam designed specifically for a set of heads.
Old 03-30-2005, 08:00 PM
SPANKY LS1's Avatar
Very very cool, it should be interesting to see a back to back test, with the cam being the only change.
Definitely, a custom cam that was precisely designed with your specific combo in mind should, hyphotecially speaking, absolutely MURDER an off the shelf, "generic" cam like the G5X3.
Shawn
Old 03-30-2005, 08:01 PM
Louis's Avatar
My bet is that you will pick up 6-8 top end, and gain maybe a little midrange.
In order to keep things civil at 7400 matt, you have trade offs.
Louis's Avatar
Murder? I highly doubt it.
Old 03-30-2005, 08:10 PM
Sport Side's Avatar
Smile
Hasn't Ed already out powered the G5X-3 in a dyno race... Maybe it was kept quiet.
Quick Reply: My new custom Ed Curtis Cam Specs...they're not small!
