any difference in ported oil pumps?
Old 04-11-2005, 11:10 AM
WS6FirebirdTA00's Avatar
Default any difference in ported oil pumps?
i see prices from 130 to 155 is there any difference in them? i want a good ported ls6 pump but if i can save a few bucks that woudl be great. let me know which place i shoudl go with
Old 04-11-2005, 12:30 PM
Derek98z's Avatar
to save a few bucks, get a nonported. I guarantee it will do the job.
But if you must have ported, see which manufacturer is doing their own work versus selling someone elses and charging more. Get one that has been dissasembled and blueprinted.
Old 04-11-2005, 12:36 PM
PREDATOR-Z's Avatar
Ditto, new stock one will be more than fine.
Old 04-11-2005, 12:53 PM
ok well i have just been reading how everyone gets the ported ones and the pressure hasnt changed much. so you say a stock one vs a ported one there really is no difference in the operation of them? and i shouldnt have to worry about turning 6600 rpm with it? anyone know the stock part number for an ls6 pump?
Old 04-11-2005, 02:03 PM
Derek98z's Avatar
I just read a thread last week that said all GM pumps are now LS6.
Old 04-11-2005, 02:13 PM
PREDATOR-Z's Avatar
Yeap, mid 2000 all LSx pumps are "LS6"
Old 04-11-2005, 03:49 PM
fastsspr's Avatar
hhmmm...
i think is time to buy one from my local GM dealer!!!
Old 04-11-2005, 04:29 PM
anyone know the part number?
Old 04-11-2005, 05:03 PM
matts22's Avatar
A stock oil pump is as good as a ported one? Really? I haven't ever heard this. Can some more people come in and back this up or refute it?
Old 04-11-2005, 05:04 PM
tonydss's Avatar
well i have a 2000 ss camaro is it bad for the oil to go under 40?? and do i need a ls6 oil pump
Old 04-11-2005, 06:00 PM
mine is a 2000 as well, my pressure is about 45 idle and then jumps up going down the road. the ls1 pumps just tend to fail more than the ls6 so its a nice to have it
Old 04-11-2005, 06:03 PM
61 bucks for a stocker is a lot easier on the wallet than 155 for a ported one, esp if there is no true gain from it.
as a matter of fact, i never hear of guys with the old cars port pumps they just get better new pump not reworked stockers
Old 04-11-2005, 06:05 PM
MikeB.RamAir's Avatar
I just got mine form Futral MotorSports and to my door
$135.00
$125.00 for the ported (by Allan) LS6 oil pump
$10.00 shipping
Old 04-11-2005, 07:20 PM
TroubledWine3's Avatar
I got the TSP ported pump. Ported in-house by the TSP guys, PSI jumped from 22-25psi to 35-40psi on the highway in 6th.
Old 04-11-2005, 07:24 PM
see im already seeing higher than those pressures with the stock ls1 pump
Old 04-11-2005, 07:42 PM
My car at idle is at 40psi and on the road 50-60psi
Old 04-11-2005, 08:20 PM
fnbrowning's Avatar
You don't buy a ported oil pump to see higher pressures. The size of any oil pump is designed produce a specific amount of flow at a given rpm. The resistance to that flow produces the pressure. The resistance to the oil flow is from the bearing and lifter bore clearances.
You buy a ported pump to get as much flow as possible from the pump design by removing unnecessary restriction in the pump.
Higher oil flow rates will move more heat away from critical moving engine parts.
Old 04-11-2005, 08:24 PM
yeah i didnt think a ported pump would really increase the pressure. but i wouldnt think the volume flow rate would change enough to matter, you would have to increase the inlet and outlet area by a lot to get it to flow a lot more, or enough to actually see a clear benefit
Old 04-12-2005, 08:45 AM
GuitsBoy's Avatar
higher pressure is a result of shimming, which is done to many ported pumps.
Old 04-12-2005, 09:01 AM
Then I went to M1 0W-40 at the reccommendation of Patman and my pressure never drops below 45. 50psi in 6th at 1500-1900rpms.
