Cam Selection... 112 or 114 lsa with the nitrous?
Old 04-17-2005, 08:53 PM
_HAVOC_'s Avatar
Default Cam Selection... 112 or 114 lsa with the nitrous?
I'm tring to choose a cam, I am going to continue to use nitrous and here is the cam that looks best to me so far.
Thunder Racing Custom Camshaft - 230/236 .590/.598 112 LSA 2400-6800 RPM Power Band. Excellent mid-range & high RPM power. 3200+ stall, 3.42+ gear
here are my Questions.
1. will the 112 lsa be ok with the nitrous? or will i have to do a 114... i really want the 112 cause i want it lopy!
2. with the above mentioned cam, will it be ok with the Comp Cams 26918 Valve Springs? id rather not spend the extra $ for dual springs If i don't have to.
my current mod list is.
| 2000 Trans Am Ram Air | M6 |
| !FRA | !Front sway bar | Lid | Jet Hot LT's | True dual exhuast with X pipe - billet mufflers | pro 5.0 shifter | BFG DR's |Spec Stage III clutch & billet steel flywheel| Eaton posi differential | 90 RWHP DryShot of N20 | LS1 edit tune |
I will also be getting some bigger injectors (not sure which ones yet) and another tune.
thanks in advance for any advice.
Old 04-18-2005, 05:54 PM
jmac_98ls1's Avatar
The 918's are good to .600 lift but you are at the verge of the max lift. you are pretty much in the same place i am i want the lope, but i want to spray a 200 shot on top of it.
Old 04-18-2005, 05:57 PM
pdd
pdd's Avatar
id check in the nitrous section, but i dont think the LSA matters to much unless your spraying over a 200 shot. so id go for the 112
Old 04-18-2005, 06:01 PM
blkZ28spt's Avatar
I agree with checking the nitrous section for truly knowledgeable advice. My semi-knowledgeable advice is to get the lower LSA. I think it will be fine. Look at a lot of hte larger cams that handle nitrous alright, like mine (MS3), they have a relatively large amount of overlap/low LSA.
Edit: Oh yes, for the first question. GET DUAL SPRINGS! It's just added insurance. THey will be less likely to break and if they do the valve will be much less likely to fall into the cylinder or be struck by the piston. There are some decent dual kits out there dirt cheap. The PRC duals being one of them.
Old 04-18-2005, 08:20 PM
7 Second Club
ty_ty13's Avatar
im about to install the same cam... however mine cam at 111.4 lsa and 230/236 589./598.
i got the com 912's with the other parts waiting to install in sig.
i plan on spraying this cam about 250ish next season... it will be fine on the juice
i cant wait to put mine in
Old 04-18-2005, 09:40 PM
B18B1LS1's Avatar
There are lots of factors but unless your running a BIG shot the 112 will fine for you. I see a 90 shot in your sig. so I think you'll be fine
Old 04-18-2005, 09:54 PM
Beast96Z's Avatar
I've always had beter luck with the 112's. Geoff from thunder even posted that whatever amount of ovelap your car likes n/a, it'll like the same on the spray. I'm sprayin a 111 LSA with no worries of power loss.
Old 04-18-2005, 10:05 PM
Another_User's Avatar
I think I would treat a nitrous cam more like a supercharger cam. It doesn't make sense to go with an LSA like 112 IMO. But I don't spray either...yet.
Old 04-18-2005, 10:11 PM
Casperws6's Avatar
just go with the 112, you'll be happy
Old 04-19-2005, 12:04 AM
crizain's Avatar
Have you guys seen any numbers on this cam yet, mine is going in this weekend!
Old 04-19-2005, 03:15 PM
prostock_bigblock's Avatar
112lsa all the way dont hesitate .
good luck
Old 04-19-2005, 03:30 PM
_HAVOC_'s Avatar
thanks a lot of all the advice! 112 LSA it is!
Old 04-19-2005, 04:36 PM
PREDATOR-Z's Avatar
You could get it straight up, no advance in the grind.
You will be limited on how big of a shot to run, that cam has a positive +9 degrees of overlap at .050.
Efficient levels will be ~150 wet (200 dry).
Quick Reply: Cam Selection... 112 or 114 lsa with the nitrous?
