Recycle MLS Head Gaskets?
Old 05-02-2005, 06:15 PM
Cal
Cal's Avatar
Default Recycle MLS Head Gaskets?
I will be removing the heads soon. Is it necessary to replace GM MLS head gaskets even though they've only been in there 4 months?
Old 05-02-2005, 06:24 PM
Nate_Taufer's Avatar
yes...once you compress them they're done.
Nate
Old 05-02-2005, 06:27 PM
Greg Fell's Avatar
I have recycled head gaskets with low miles on it with no problems. It is not advisable, but if there are no tears on them, you will probably be ok.
Old 05-02-2005, 06:44 PM
Cal
Cal's Avatar
OK, thanks guys . . . that's about what I thought.
Old 05-02-2005, 06:57 PM
ROCNDAV's Avatar
what about after torquing them down to check P/V clearance or pushrod height.
Its ok then, as long as the engine hasnt been started right?
David
Old 05-07-2005, 03:46 AM
OnE Ls1 2 HaTe's Avatar
ttt!!! i also wanna know?
Old 05-07-2005, 04:48 AM
seriously don't reuse your mls head gaskets. once they've been compressed and un-compressed they've seen their useable life span... just spend the extra 26 bucks and buy a new set at napa.
Nate
Old 05-07-2005, 12:59 PM
ROCNDAV's Avatar
$26 bucks at Napa, are you sure? Whats the Napa PN?
D
Old 05-09-2005, 08:36 AM
GuitsBoy's Avatar
D
Yeah, hook us up with a part number! Or did you mean 26 each, in which case Ill just buy from GM.
Old 05-09-2005, 09:09 AM
C_Williams's Avatar
No, don't even consider it.
Old 05-09-2005, 09:58 AM
ArcticZ28's Avatar
What kind of MLS gaskets are these that you can get at NAPA? Seeing as how Cometics are $75 a piece, where do those fall in quality?
Old 05-09-2005, 11:35 AM
zamboxl's Avatar
if u are using COMETICS mls gaskets u might be able to get away with it, stock gm mls gaskets? sure u can but then those gaskets will go the first chanse they get.
