scratching noise when installing head bolts.
Old 05-06-2005, 11:13 PM
OnE Ls1 2 HaTe's Avatar
Angry scratching noise when installing head bolts.
i torqued my head bolts down ( new stock bolts ) and i heard a scratching noise. they all torqued to spec though. im worried. also if i did make a crack in the bolt hole would it even torque down or would the bolt move easly? i also did the whole 90 degree thing twice. am i fucked or what!
Old 05-07-2005, 09:11 AM
DrkPhx's Avatar
Is this on all of them? You might have some dirt or other contaminants in there. Did you clean the bolt holes with compressed air?
Old 05-07-2005, 11:09 AM
HAMRHEAD's Avatar
Make sure you clean the bolt holes good with an old modified head bolt and some compreesed air. Just sounds like the threads need to be cleaned.
Old 05-07-2005, 12:54 PM
Brains's Avatar
Actually, I'd bet its water. What you're hearing (and should also be feeling in the ratchet/torque wrench) is water squeezing through the threads. STOP NOW and pull all the bolts back out, and get the water out of the bolt holes. You will likely crack the block if you continue!
Old 05-07-2005, 01:02 PM
Cal
Cal's Avatar
Yep, I second this. Slot a used head bolt length wise through the threads converting it into a thread chaser.
Old 05-07-2005, 01:43 PM
Tech's Avatar
You might be fucked. Should have read LS1howto.
Old 05-07-2005, 06:16 PM
i did read ls1howto's. has anyoneever got lucky, i bet some gm work do this and not say anything and everything is fine, right?
Old 05-08-2005, 07:49 AM
Z06 Steve's Avatar
any pics of a modified head bolt and how it was fabbed?
Old 05-08-2005, 08:17 AM
2c5s's Avatar
Old 05-08-2005, 09:42 AM
lilbuddy1587's Avatar
Dont ask for help and then question the answers or "opinions" of others with lots of experience such as brain
