When Fly-cutting pistons...
Old 05-10-2005, 03:44 PM
SideStep's Avatar
Question When Fly-cutting pistons...
When Fly-Cutting pistons how high should the piston be in the cylinder???
Old 05-10-2005, 04:33 PM
Demon SS's Avatar
top dead center
Old 05-10-2005, 04:40 PM
SideStep's Avatar
Originally Posted by Demon SS
top dead center
There is not enough room under the cylinder head with the piston at TDC for the fly-cutting tool... I got the one from Isky, 2-1/4 (2.06).
***Edit***
I may be using a different tool from what most use. I got the tool from ThunderRacing
http://www.thunderracing.com/catalog...&vid=7&pcid=17
I am going to the garage to take some pics...
Old 05-10-2005, 06:41 PM
WickedS6's Avatar
as far as i know you need a scrap set of heads with the valve seats REMOVED and the cutting tool takes the place of the seats. thats probably why you don't think you have the room. heres a nice wright up i found.
http://www.forcefedhighperformance.com/tech_Isky.htm
If anyone else is interested, i have a second set of 98 heads i'm not going to use, and eventualy was going to do this with, i can cut you off a cylinder and you can use that.
also i noticed you said this...
2-1/4 is 2.25, not 2.06...
Old 05-10-2005, 06:46 PM
ssheets's Avatar
I wonder if there's any scrap heads floating around that can be borrowed for this? (I might be performing that procedure myslef.)
SideStep's Avatar
Yes you are right!!!
I just got off the phone with Tony (AFR) and he explained the whole ordeal to me... I have a set of LS1 241 heads and I am going to get the valve seats mahined out so the tool will sit up in the head.
Thanks, Tony and everyone else that posted
Old 05-10-2005, 06:50 PM
WickedS6's Avatar
re read upper post... 2-1/4 isn't 2.06... it's 2.25
Old 05-10-2005, 06:58 PM
SideStep's Avatar
Your right... was thinking about about giant valves and typing about something else...
Old 05-10-2005, 07:48 PM
SideStep's Avatar
...If anyone else is interested, i have a second set of 98 heads i'm not going to use, and eventualy was going to do this with, i can cut you off a cylinder and you can use that...
Hey I am interested in that, IM sent...
Old 05-10-2005, 08:51 PM
bigdsz's Avatar
You need to set the piston at TDC with a dial indicator. Also the piston rocks back and forth on the rod pin. FWIW the guy that did my notching used 1/4 of a head. That way he didn't have to keep moving the cutters. Surprisingly he never thought of using tape to keep the filings out of the cylinders, or using a feeler gauge to set the depth of the collar.
Old 05-10-2005, 09:17 PM
ArKay99's Avatar
I don't know if this is allowed here, but I have an 853 head cut for the tools and a set of Isky cutters and shafts I can rent and maybe we can work something out. If you are interested give me a PM. I just did this on my 99 C5.
Old 05-11-2005, 07:38 AM
SideStep's Avatar
PM sent...
I am going to try to cut mine in the next week or so, any help would be appreciated
Old 05-17-2005, 10:59 PM
sandking's Avatar
When you rent the tool, does it come with two cutters? One for the intake and one for the exhaust?
Old 05-18-2005, 09:05 AM
Restricted User
2001 Pewter WS6's Avatar
The piston needs to be top dead center and you just need to remove the valve seats from an old head. I had to double up the gaskets to get enought clearance for the tool to fit properly. Make sure you use a dial caliper to measure the length of the cut to keep them the same depth. You will see what I mean once you cut a couple.
Old 05-18-2005, 11:57 AM
bigdsz's Avatar
Force Fed HP has a write on this site that shows you exactly how to do it. Use the dial indicator to get TDC, but use a feeler gauge between the cutter collar and where the valve seals sits to get the correct depth. This is not exact science so there will probably be .010-.015 differences in notch depth.
