My ALL PRO Heads install
Old 05-28-2005, 11:37 AM
MIGHTYMOUSE's Avatar
Default My ALL PRO Heads install
heres the pics:
http://www.fastrides.com/photos/mm/i.../original.aspx
these were bought from wheel 2 wheel.. kurt can fill in the specs that are on the spec sheet i dont have yet he was busy yesterday playing with his truck.
comments:
stock 6.0 mls gaskets are sharp! dont try to slide them over studs. 2 nice cuts on opposite hands
tq'd to 80 and 24 w/ oil
apparently the acessory mount holes are not as deep, i had to cut about 1/4" off of the ps bracket bolt to get it back flush.. and used shorter ones on the other two.
also the valve cover screws do not lock down, they just keep tightening and tightening.. so you have to use judgement on when the gasket is compressed.
- you have to use 99+ valvecovers... maaan i hate em!
my front coolant crossover tube had to be bent a little bit to line up, but that may have happened getting turbo crap piled up on it in the back of the car.
*EDIT*
also it seems the spark plugs sit deeper in the hole and it makes the spark plug wires tight to reach.. not too tight but borderline.. a solution if it really bothered someone would be some truck wires with are an inch or so longer.
i may have to switch pushrods, not sure yet, these heads are taller than my last set (lower CR) but its not really loud.. maybe a little rattle when reving. feels solid and strong so far, only 10psi (new clutch). will be racing at MIR next sat.
Old 05-28-2005, 11:55 AM
TT-TECH Veteran
Inspector12's Avatar
Looks good David I've been waiting on your opinion of them so let us know what you think after you get a little time on them.
Old 05-28-2005, 12:04 PM
Squintz Palladoris's Avatar
Nice Pics Man!
The Quality of the CNC work in the chamber is Gorgeous!
Brad
Old 05-28-2005, 01:57 PM
Restricted User
CAT3's Avatar
So these heads only had a minor touch up around the guide area but not the intake runner?
With the PS and other accessories all lined up like it should, no issues with shorter bolts?
Will be waiting for feedback...
Charlie
Old 05-28-2005, 02:32 PM
BigBronco's Avatar
Looks good, want to see how these perform..
Also interested to see what they flowed as well!
Old 05-28-2005, 02:54 PM
Charlie
there is no belt allignment issues if thats what you mean.. i just had to use shorter bolts to secure the pump bracket to the head.
yes they did some minor work to the bowls but no runner porting or matching at all... gives me something to upgrade in the future
Old 05-28-2005, 03:02 PM
NA$TY-TA's Avatar
Looks good David..... You hitting the dyno before you go back to the track????
When did Kurt say he would be able to get you the sheet???
Kyle
Old 05-28-2005, 04:23 PM
SSU Moderator
RyanJ's Avatar
Do you know what valves and springs are in them?
I think you should spring for some ARE (NOT Agostino!) valvecovers...the ones with the oil squirters.
Old 05-28-2005, 05:27 PM
NA$TY-TA's Avatar
He told me they are the Comp 921 springs.........
Old 05-28-2005, 06:55 PM
JZ'sTA's Avatar
Looks good.
Wondering about the flow numbers myself.
Old 05-28-2005, 07:06 PM
White.Lightning's Avatar
Looks good Dave. Good luck with them. Once you get dialed in, I am curious to see if there is any gain from using these heads versus the old setup.
Andy
Old 05-28-2005, 09:34 PM
Mike K.'s Avatar
damn looks nice, must be nice to have a turbo.
Old 05-28-2005, 10:28 PM
98TAauto's Avatar
gimmie some of your money lol you gonna bring the new setup to the EFA shootout on the 4th?
Old 05-29-2005, 01:35 AM
of course!
i floored it tonight.. spun same as it did before so can't tell much from that.. but what can you expect from a 315 drag radial
tried to get on some rollers this evening but they were closed up.
hey cut the house and wife and kids out of your budget and you'll have some for heads
Old 05-29-2005, 02:26 AM
ssheets's Avatar
Originally Posted by MIGHTYMOUSE
of course!
I was just doing that budget proposal
Old 05-29-2005, 03:32 AM
1a-play's Avatar
looks good Dave- how much are these going for?
Old 05-29-2005, 07:00 AM
Tenured Member
Joe Racer's Avatar
*EDIT*
This is most likely due to the fact that the valve cover rails are raised .250" To clear shaft rockers without having to use spacers.
Old 05-29-2005, 07:32 AM
427's Avatar
They have a hollow 8mm stem intake valve, a inconel 5/16 ex valve. The springs are 921 comps with the matching ti retainers and Manley machined locks. The chamber is standard large chamber program on CNC machine. The ex bowl was worked on because we new what David would be doing. The intake was untouched except a little de-burr around the guide.
Kurt
Old 05-29-2005, 10:00 AM
there you go. i didnt have any heads in front of me to compare
thanks kurt, the large chamber cnc is the 76 cc correct?
.....beating them to within an inch of their life?
