MTI or AFR heads?
Old 05-29-2005, 08:51 AM
Phil'sC5vette's Avatar
Default MTI or AFR heads?
Im on the market for new heads.
I have the TR224 cam and kooks headers
How much performance differance between the two heads.
I want to be at or just under 11:1 compression.
If im only lossing a couple RWHP. like 10 Im thinking about MTI heads
what's your car like with either
Old 05-29-2005, 10:46 AM
52172's Avatar
I would get some AFR's for sure they are the best since they have a thicker deck and just a better casting since they are aftermarket castings. I believe
they quench better also so you can run a little more compression with a given gas octane.
Old 05-29-2005, 10:51 AM
scalemaster's Avatar
I got the stage 2R and seems to be working great there not mill so when I get the bottom end strock'd I can use a huge cam
but for the money I think MTI iare good
AFR's are too exp
Old 05-29-2005, 11:02 AM
PREDATOR-Z's Avatar
If money is not an issue and quality is what you seek along with best performance then AFR is definitly the way to go.
Old 05-29-2005, 12:07 PM
INVISIBLEZ's Avatar
Another vote for AFR's...
Old 05-29-2005, 12:48 PM
01FbTaWs6's Avatar
afr's is the way to go. They have done far more research and development to get the most out of there castings, also have unsurpassed flow for the price. A little extra money=better heads in the long run.....
Old 05-29-2005, 12:56 PM
JZ'sTA's Avatar
AFR 205 vote here
Old 05-29-2005, 01:03 PM
1QuickT-A's Avatar
AFR's... hands down!
Old 05-29-2005, 01:33 PM
mike c.'s Avatar
i had mti heads and now i have AFR'S. if you don't go with afr's your loosing out.
Old 05-29-2005, 04:50 PM
SideStep's Avatar
Funny... I was the first to post in here and some how my post got deleted...
I said the same as others above.. If you have the money go AFRs, if not do the MTIs. I have owned both....
Old 05-29-2005, 05:49 PM
52172's Avatar
I think if I didn't have the money I would purchase prc stage 2.5 or tea stage 1.5 5.3's they are both 1500 without core charge and they flow just as well maybe a little better than the cnc'd afr's. Just a thought.
Old 05-29-2005, 07:23 PM
WILWAXU's Avatar
IMHO, if you are building a NA 346 motor, the MTI Stage 2E are the way to go.
for $1700, they are a hard combo to beat.
Old 05-29-2005, 07:50 PM
SS1875's Avatar
I vote for LPE LS6 heads.
Old 05-29-2005, 08:25 PM
jrp
SN95 Director
jrp's Avatar
nobody deleted your thread, are you sure you hit the "submit reply" button?
and my vote is AFR.
Old 05-29-2005, 08:40 PM
99CamaroSS_'s Avatar
You would go with the tea stage 1.5 5.3's? i was wondering this myself if i should get the tea or the afr 205. I have been debating it myself, it seems that the tea's flow better...
Old 05-29-2005, 08:47 PM
guys,
Im just looking for the AFR and MTI guys only.
I love the response of you've had both heads and like one more than the other
but we are on the right track with this thread
Old 05-29-2005, 08:48 PM
jrp
SN95 Director
jrp's Avatar
TEA's have a core charge. and you should know by now that flow numbers arent everything....
Old 05-29-2005, 09:15 PM
hearing from guys that have been been with both heads is helpful
Old 05-29-2005, 10:07 PM
Ed Curtis's Avatar
Cool
Tested a lot of heads...
Put AFR 205's on the GTO.
Ed
Old 05-29-2005, 10:26 PM
C_Williams's Avatar
Ed
AFR's
