H/C Upgrade - Do I need a Double Roller Timing Chain
Old 06-02-2005, 06:26 AM
JG853's Avatar
Default H/C Upgrade - Do I need a Double Roller Timing Chain
Hello:
I recently purchased the following mods:
Hello:
I just recently purchased the following mods for my 02Z06:
AFR 205 Heads (Milled for 11:1 Compression Ratio)
G5X-2 112 Cam (With all of the Retainers, Pushrods, etc)
Comp 921 Springs
LG Long Tube Headers with Random Tech Cats
Vararam Intake
ASP Underdrive Pulley
Comp R Lifters
Thermostat
Injectors
I have not put these yet (And it will get tuned). I also have a Corsa Titanium Exhaust.
Do I need to install a Double Roller Timing Chain (If so, what kind - I was considering the Rollmaster Double Roller Timing Chain)? Or is it better to leave the stock chain in it? I do not race or drag the car, just want to be sure it is reliable.
With a double roller timing chain, are there timing issues?
For guys that have H/C Upgrades - Do you have a double roller timing chain? I need advice from the experts on this forum.
Old 06-02-2005, 06:53 AM
nostyta's Avatar
When I had my h/c package installed I went ahead and put the double roller timing chain in, you don't really need it but it is a cheap and easy upgrade since your going to have the motor apart-no timing issues either. I used the SLP setup but Rollmaster or Comp. would be good to.
Old 06-02-2005, 07:00 AM
conan's Avatar
I put the rollmaster double in when I did my engine build. Some say its over kill but thats fine with me. You could also look in to the LS2 timeing chain there has been alot of good feedback with that too. I would also get a ported LS6 oil pump while your in there. Good luck with your new power.
Old 06-02-2005, 07:55 AM
777's Avatar
nothing wrong with overkill...
Old 06-02-2005, 08:26 AM
PREDATOR-Z's Avatar
No need, single is fine and more than enough. LS2 or if you want a better single, then J-wiss. (C5R chain).
Most builders will offer replacement chains with their blocks unless specified otherwise.
Personally i think doubles are too tight and could cause front cam bearing wear (Although I've not seen a study on this).
Also, shimming the pump for clearance is a PIA, and with a single you do not have to replace crank sprocket either (unless damaged)
As far as toughness, I've seen doubles break and singles, but in either case, they are far between.
BTW are you going to flycut your pistons???
Old 06-02-2005, 08:47 AM
JG853's Avatar
Predator-Z
I am not fly cutting the pistons. My AFR 205 are being milled to 61cc. Then I have a .045 gasket. I purchased from LG and they told me that I will be fine and will not have any clearance issues. Now if I wanted to run the mill to 59cc, then I would have to fly cut.
Even at 61cc I can still run 11:1 compression.
Old 06-02-2005, 08:51 AM
JG853's Avatar
[QUOTE=JG853]Predator-Z
Where can I purchase a C5R chain?
Also, I want to get SVO #30 injectors.
Who offers the best price on these two items?
Thank you
JG853
Old 06-02-2005, 09:39 AM
cyphur's Avatar
Who makes a good adj single chain?
Old 06-02-2005, 10:38 AM
PREDATOR-Z's Avatar
C5R chain is called J-WISS, Thunder racing carries them as well as SVO's. You just missed their Memorial Day Sale.
Let your clicking do the walking>>>>>>All sponsors to the right.
