Yet another Cam Thread F13 or G5x4
Old 06-16-2005, 01:19 PM
BAN-LS1's Avatar
Default Yet another Cam Thread F13 or G5x4
Getting really close to buying a cam. I am looking really hard into the F13 on a 112+0, but the g5x4 has me very interested. There are no listed number, can somebody pm me with the numbers. Also where does this cam peak and which would you choose.
Car is 02 Firehawk m6 will have all bolt ons & 4.10's. weekend car, don't mind all the stuff that comes with larger cams, will spin the motor 6800.
Thanks for the help
Old 06-16-2005, 04:07 PM
blkZ28spt's Avatar
There is a large difference in size between an FM13 and G5X4. LARGE.
Between the two I'd get the G5X4. Do you run at the track? If so, are you ready to buy a new rear end and strong clutch? You probalby won't get anybody to tell you the specs on the cam, lou is different like that and doesn't make them public. It's BIG though. Probably not T-rex big, but big nonetheless.
Old 06-16-2005, 04:55 PM
BAN-LS1's Avatar
Yes, and yes. Stage 3 clutch and when the rear goes its time for a upgrade. I know what to expect with the F13, but not so much with the g5x4. How is it from 2500-4000, what is the expected life for valve springs?
Old 06-16-2005, 05:04 PM
blkZ28spt's Avatar
Do a search on the G5X4 and other larger cams, such as the Magic Stick v.3 and T-rex. (T-rex being bigger than anything else), Also read the stickies/guides.
Old 06-16-2005, 05:19 PM
Beast96Z's Avatar
The X4 isn't that much bigger than the F13. Maybe 6 degrees of duration @ .050". Both cams are similar in lobe harshness, but the F13 goes reverse split around .200" whereas the X4 is just a traditional foward split throughout the lift range. Springs will wear a bit quiker with the bigger XE-R lobe of the X4, but the F13 wouldn't be too far behind it in spring life. I think it just depends if you want big or bigger.
Old 06-16-2005, 05:25 PM
BAN-LS1's Avatar
Thanks for your help! I wouldn't mid something bigger than the F13 (not T-Rex big though!) and it seems that the f14 and f15 don't make much more power and thats why I am looking at LG. Will the G5X4 make more power/torq than the f13? If you have a G5X4 Graph post it up please with list of mods.
Old 06-16-2005, 05:31 PM
blkZ28spt's Avatar
G5X4 will make more power than the F13.
Old 06-16-2005, 05:35 PM
Beast96Z's Avatar
The X4 will make more power. It's simply bigger. It would be a good inbetween from the F13 to the T-rex.
Old 06-16-2005, 05:40 PM
BAN-LS1's Avatar
i'm on the phone with a rep from lg he said the x4 is for strokers??? too big for 346
Old 06-16-2005, 05:51 PM
blkZ28spt's Avatar
I told you it's big. Don't know why they say it's too big for 346 though.
Old 06-16-2005, 06:03 PM
Beast96Z's Avatar
It's not that big. Like I said, without being to specific, it's in the 236'ish range on the intake and 244'ish on the exaust. Deffinatlly not to big by todays cam standards. It is however very tight on piston to valve clearence. You better make sure you have a stout spring like the PRC platinum to keep it under control. It really depends on what you want. The X3 would also be a good choice and allow a little more P/V.
Old 06-16-2005, 06:11 PM
98TA86's Avatar
ive got the f13 and i love it .. the g5x4 would make more power b/c it's huge but i would think driveability wouldnt be to great on the street with that cam???
i dont think you can go wrong with either cam ... just depends on ur goals for the car
Old 06-16-2005, 06:13 PM
Tranzor's Avatar
Dude... that's big when you're talking stock cubes. Not too big, but getting there. The F13 is 230/232, there's a huge difference between that and 236/244. That's like saying there's not much difference between a 220 or 222 duration cam and the F13.
I dunno... maybe we have different opinions on what similar cams are. To me, X4, T-Rex, and MS03 are more alike. F13, Torquer v.2, and maybe X2 or X3 are more alike.
Old 06-16-2005, 06:15 PM
blkZ28spt's Avatar
F13 is far from G5X4 in almost every way.
Old 06-16-2005, 08:51 PM
Beast96Z's Avatar
To me, six degrees of duration isn't that much. In the opinion you posted 8-10 degrees being a big diffrence. That is far more substantial than 6. There is no magical number to being to big. It's all just personal opinions. IMO, anything under 240 isn't that drastic and could be tuned to be a good driver in a M6. The F13 is far diffrent than the X4, but not just because of the .050 numbers. There is far more to the equation than what you see at .050", but even at .050 the X4 has double the amount of overlap of the F13. As far as my statements, I was saying that at .050", to me, the X4 isn't that much diffrent, but the cams are actually two completly diffrent animals.
Old 06-16-2005, 09:48 PM
blkZ28spt's Avatar
Just go big. I daily drive a 237/242 in an A4 and have zero problems. It's all in the tune.
Old 06-16-2005, 09:55 PM
ssfirefighter's Avatar
I have the x4 in a daily driver and I love it. I had the old 224 in there for ever, and the x4 is just as drivable, if not better than the 224.
jrp
SN95 Director
jrp's Avatar
FM13
.050 - 230/232
.200 - 151/150
X4 (guestimates)
.050 - 236/244
.200 - 157/165
Old 06-16-2005, 11:14 PM
DONAIMIAN's Avatar
what rear gear are you running
Old 06-17-2005, 01:35 AM
White 02 WS6's Avatar
Bigger isnt necessarly better in all cases...It is all in the setup that each part compliments one another...I know some small 221 221 cars putting 400 to the wheels cam only, a G5X3 cam only car putting down 385, yet another 224 224 C2 cam and ported heads running 10.7's all motor in a full weight 3800lbs car...Just get what you feel you will be happy with and what works with your setup...Just my .02
